External ip
sdarby
External ip
Hi, is there anyway to find out my external IP from the Plusnet portal? I haven't had chance to setup ddns and I'm not currently home to get it. Thanks.
4 REPLIES 4
Jaggies
Re: External ip
I'm not sure if there's a way to get it on the Portal, but if you go to https://whatismyipaddress.com/ you'll be able to find it.
sdarby
Re: External ip
Thanks for the response but I'm not home at the moment so was looking at a way of finding it. What's my IP only works from the location you want the ip of.
Fixes: 380
Re: External ip
@sdarby As @Jaggies says, you cannot get it from the Portal, and as you say, WhatsmyIP (or similar) will only give you the IP of the connection you currently have.
Re: External ip
This information might also available on your router when you are at home.
On my Plusnet Hub 2, if I go to Advanced Settings > Broadband I can see my "Broadband IP address" under "TCP/IP information".
