Ethernet Not working, Wireless fine?
sanctuary
Greetings.
I had my Fiber Plusnet installed a few days ago (Tuesday the 4th to be exact) and have only today managed to get it up and running after a talk with customer service.
Now, in a nutshell. I can get online and browse via the Wireless ( Am currently tethering the connection to my desktop) however, every computer I try to connect with a Wired connection, it wont seem to work (Limited or no Connectivity) and I have tried 2 computers, and 2 different cables. Same thing.
I'm pretty much out of idea's. Can anyone please shed some light on my situation.
Also, the router is the Technicolor TG582n FTTC
Thanks!
8 REPLIES 8
adamwalker
Fixes: 223
Re: Ethernet Not working, Wireless fine?
It sounds like a fault with the router to me, have you tried a factory reset?
Adam
 Adam Walker
ReedRichards
Seasoned Pro
Fixes: 25
Or it could be you set fixed IP addresses on those devices that don't fall within the range used by your new router.
sanctuary
Quote from: ReedRichards
How would I check this, and or solve the problem if it is the case?
Also, no. I have not factory reset, I was worried about breaking my new connection Sad
sanctuary
Here is the CMD if it will help, bare in mind I'm currently using the Wireless tethered to my computer to post here, let me know if you want a CMD with the ethernet in.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\sanc4>ipconfig/all
Windows IP Configuration
  Host Name . . . . . . . . . . . . : Kyle-PC
  Primary Dns Suffix  . . . . . . . :
  Node Type . . . . . . . . . . . . : Mixed
  IP Routing Enabled. . . . . . . . : No
  WINS Proxy Enabled. . . . . . . . : No
  DNS Suffix Search List. . . . . . : mshome.net
Ethernet adapter Local Area Connection:
  Connection-specific DNS Suffix  . : mshome.net
  Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
  Physical Address. . . . . . . . . : 48-5B-39-78-90-B8
  DHCP Enabled. . . . . . . . . . . : Yes
  Autoconfiguration Enabled . . . . : Yes
  Link-local IPv6 Address . . . . . : fe80::f414:7f9e:86a:ddcb%10(Preferred)
  IPv4 Address. . . . . . . . . . . : 192.168.0.222(Preferred)
  Subnet Mask . . . . . . . . . . . : 255.255.255.0
  Lease Obtained. . . . . . . . . . : 10 December 2012 15:55:12
  Lease Expires . . . . . . . . . . : 17 December 2012 17:52:23
  Default Gateway . . . . . . . . . : 192.168.0.1
  DHCP Server . . . . . . . . . . . : 192.168.0.1
  DHCPv6 IAID . . . . . . . . . . . : 239622969
  DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-AE-8D-80-48-5B-39-78-90-B8
  DNS Servers . . . . . . . . . . . : 192.168.0.1
                                      192.168.1.1
  NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.mshome.net:
  Media State . . . . . . . . . . . : Media disconnected
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter
  Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
  DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
  Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
  IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:4fe:100f:a956:43ce(Prefe
rred)
  Link-local IPv6 Address . . . . . : fe80::4fe:100f:a956:43ce%11(Preferred)
  Default Gateway . . . . . . . . . : ::
  NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Users\sanc4>
jelv
Fixes: 10
That confirms that the networking settings on the PC are almost certainly the problem.
You need to go to the properties of the Local Area Connection and check that both Obtain an IP address automatically and Obtain DNS server address automatically are selected.
http://www.plus.net/support/software/dns/changing_dns_vista.shtml up to step 5 will take you to the right place.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
sanctuary
Quote from: jelv
Dude, it worked.
You are the man. Thanks!!! ❤️
jelv
Fixes: 10
You'll find these bits have change to 192.168.1.x
Quote from: sanctuary
   DNS Servers . . . . . . . . . . . : 192.168.0.1 - this has probably disappeared
                                       192.168.1.1
sanctuary
Indeed. The IP 4 was set to resolve the DNS non automatically, it fixed it right up
Thanks again!
