Error 550 Relay Not Allowed
- Error 550 Relay Not Allowed
12-09-2008 10:33 AM
When I travel abroad I get the messsage "Error 550 Relay Not Allowed" when I try to send a message.
I took this up with Plusnet and after telling me to try this and try that they eventually told me that the only way to send message whilst away was via Webmail!
I cannot face mucking about with gmail etc.
This is an anti-spam device/technique.
This isn't very sensible.
I understand that Ebay now in addition to the normal login requires an additional security procedure if you access Ebay from a different IP address.
I don't see why Plusnet, which is used to me sending emails from this IP address, cannot allow me to send emails from abroad.
Until this is sorted out I have to put Plusnet in the amateur category for ISPs.
Re: Error 550 Relay Not Allowed
12-09-2008 10:37 AM
Basically, you can only use our outgoing email server to send emails when you are connected to us. This is VERY common as it prevents people signing up for free accounts and spamming the living daylights out of everything and getting ourselves put on various blacklists.
However, what you can do, is use something called authenticated SMTP. Where you set the outgoing mail server in your email client, there should be an option to use a username and password. Just use the same password as incoming mail and you should be able to send email when not connected to us.
12-09-2008 10:38 AM
My advise would be go into Outlook, go to the account settings and set it to use SMTP authentication, the username and password you should use are those of your default mailbox (just your account username) and this should allow you to send via relay.plus.net from anywhere.
Hope this helps.
12-09-2008 11:11 AM
Seems sensible, but I didn't know we could use SMTP authentication.
But when I was waiting for my B/B to be migrated from previous ISP I was I couldn't migrate my email until B/B was active, as you couldn't access SMTP from outside the PN network ??.
What's the difference please ?
12-09-2008 11:12 AM
12-09-2008 11:31 AM
12-09-2008 12:28 PM
Quote from: Jameseh Just use the same password as incoming mail
I think that you need to use the ID and password of your plusnet account rather than your mail ID / PW.
12-09-2008 1:01 PM
12-09-2008 1:10 PM
Quote from: mooneyfamily I use Vista and Outlook. When I travel abroad I get the messsage "Error 550 Relay Not Allowed" when I try to send a message.
when you was advised to use Webmail I think plusnet were advising using the Webmail on their portal which is probably easier if you can not face mucking about etc.
12-09-2008 6:57 PM
It's ludicrously easy - just go to webmail.plus.net from any PC connected to the web (even a cybercafe), enter your Plusnet email username and password, and you're in.
Doddle.
12-09-2008 11:10 PM
I am sorry to tell you that all ISPs are not the same, my brother on BT does not have any of these issues.
Are you saying that if I set this up as you suggest then can then forget about it or do I need to change it when I am at home?
Webmail is a method of last resort.
12-09-2008 11:22 PM
Note that Authenticated SMTP must *not* have Secure Password Authentication selected, some email clients turn this on by default alongside Authentication.
12-09-2008 11:53 PM
Quote from: mooneyfamily I am sorry to tell you that all ISPs are not the same, my brother on BT does not have any of these issues.
More ISP probably will go down this route I feel.
Also you will find when you a using wifi hotspots or wifi in hotels that their will block smtp traffic to all servers except their own. If it's an hotel then contact the Business centre for the smtp server to use otherwise webmail is your only option. I'm sure someone will correct me if I'm wrong but if you use GPRS to access the net the mobile operators also block traffic to smtp servers except their own.
13-09-2008 7:09 AM
Quote from: itsme if you use GPRS to access the net the mobile operators also block traffic to smtp servers except their own.
My parents use a Vodaphone dongle as their only access to the Internet as they cannot get fixed line broadband in their part of Milton Keynes, and they spend weeks at a time on their narrow boat. They are using plusnet authenticated SMTP with no problems.
16-09-2008 3:28 AM
Can you put anybody's f9 account holder in SMTP username and passwords but leave everything else the same?
I was advised by plusnet to have one account for me payg and the other a fully paid up account for my partner. Will it work?
We both have web sites and want to keep e-mails separate it came about because we moved in to a new house together i.e. 2 houses in to one
Puddy
