Email Help
- Email Help
Email Help
24-11-2008 1:18 PM
I recently moved into a shared house with an internet connection (also Plusnet) so cancelled my broadband. This however has deleted all my email addresses with only 24 Hours notice i think!
Is it possible to restore my email addresses or setup a PAYG account with the same username to keep my email address. Would this work, and how would i go about doing it?
Many thanks
Craig
Many thanks
Craig
Message 1 of 3
(854 Views)
2 REPLIES 2
Re: Email Help
24-11-2008 1:20 PM
Hi Craig,
If you call CS they should be able to reopen your account as a free dialup type.
You may need to readd your mailboxes though as it's likely they'll have been destroyed.
Message 2 of 3
(254 Views)
Re: Email Help
24-11-2008 1:28 PM
Ta very much.. All sorted..
No worries about the mailboxes, was just concerned about the one address.
Message 3 of 3
(254 Views)
