Delay in connecting to relay.plus.net
- Delay in connecting to relay.plus.net
20-11-2008 4:14 PM
Since late last night I am finding it difficult to send and receive emails. "Failure to connect to relay.plus.net" is the error message with "permission denied" sometimes.
It does not seem to be a problem at my end.
Any suggestions, please?
Thanks,
Alex
Thanks,
Alex
Message 1 of 4
(1,277 Views)
3 REPLIES 3
Re: Delay in connecting to relay.plus.net
20-11-2008 7:09 PM
Are you authenticating when sending email? Or just connecting to relay with no username/password details?
I've just tested this from my home connection via both methods and had no problems.
What do you get if you try to send via telnet?
Message 2 of 4
(508 Views)
22-11-2008 10:26 PM
I have to type my username and password when I log on, but I send and receive emails without a password. The delay in sending and, sometimes, in connecting to Internet is not always there. Most of the time it works fine, which leads me to believe that this is Plus.net problem. Too much traffic perhaps?
Thanks,
Alex
Thanks,
Alex
Message 3 of 4
(508 Views)
24-11-2008 1:15 PM
Heya,
If it were a Plusnet problem I'd be expecting to see a number of similar queries.
Have you ruled out your antivirus/firewall software causing the delays?
Message 4 of 4
(508 Views)
