EE Store (EX BT Store) - access problems - internet routing error?
Champnet
Fixes: 21
Re: EE Store (EX BT Store) - access problems - internet routing error?
@thackie2015  Thanks, that’s blown the routing theory.
@sharpecd  Do you get any error message when the site fails to load ?
@Champnet
Thanks, that’s blown the routing theory, not necessarily
plusnet have many IP Address ranges for static and dynamic see here:- https://ipinfo.io/AS6871
@sharpecd @thackie2015
Can you use what's my IP Address and report which networks you're on https://whatismyipaddress.com/
thackie2015
Hi not sure if i have thecorrect info but using the posted link i have my ipv4 address which under the info tsb says isp british telecommunications plc services none detected and strangley likelystatic ip.
Hope that helps
greygit1
I'm on a dynamic IP (albeit one from a /24 pool assigned to FTTP - yup, I've tested the size of the pool).
The link https://store.ee.co.uk/ works for me.
sharpecd
Weird - it started working for me about 5pm. I've seen this before, will probably fail again some time tomorrow.
I'll report back!
Thanks for all the interest / help on this, much appreciated.
Fixes: 580
@sharpecd now its working, check and make a note of your IP address using the link posted by @Dan_the_Van above.
Then, when/if it stops working in the future, check again to see if the IP address is different. That will hopefully help identify what the problem may be
sharpecd
Still working this morning 😃. Maybe the PlusNet (BT?) guys have been secretly monitoring this dialogue, and have done a tweak.😋
@MisterW  Have noted my own IP address. I think it's a dynamic address, and I don't expect that to change unless I reboot my router.
