EE Store (EX BT Store) - access problems - internet routing error?
sharpecd
Hi.
I'm on PLUSNET broadband. As an ex BT employee I've always supported the BT shop (great alternative to Amazon).
The BT shop has now become the EE shop. However, since the change to EE branding I seem to have frequent problems accessing the site (store.ee.co.uk) via my PLUSNET broadband connection.
I have no problems accessing any other sites,
I have no problems accessing the EE store from my mobile 4G connection.
I have no problems accessing the EE Store using broadband in other non-PLUSNET locations.
This looks like an internet routing problem? Any thoughts?
Here's some techy info:
Ping to store.ee.co.uk: "Request timed out".
(Ping to www.ee.co.uk - no problem)
Tracert to store.ee.co.uk gives this:
Tracing route to store.ee.co.uk [62.172.48.1]
over a maximum of 30 hops:
1      1 ms       1 ms       1 ms      dsldevice.lan [192.168.1.254]
2       7 ms      6 ms       7 ms      172.16.12.249
3        *             *              *             Request timed out.
4      10 ms   11 ms   10 ms    140.hiper04.sheff.dial.plus.net.uk [195.166.143.140]
5       12 ms   11 ms   11 ms    gre1.colindale.ukcore.bt.net [194.74.65.225]
6        *             *             *              Request timed out.
7        *             *             *              Request timed out.
8        *             *             *              Request timed out.
21 REPLIES 21
Mustrum
Fixes: 81
Re: EE Store (EX BT Store) - access problems - internet routing error?
Try https://store.ee.co.uk/
HTH
@sharpecd
It is very likely store.ee.co.uk does not respond to ICMP (ping) so those tests will fail.
For windows it is possible to test the connection using this command
Windows Key +R, in the run box enter powershell
tnc is shorthand for Test Network Connection
tnc store.ee.co.uk -Port 443
Champnet
Fixes: 21
No problems connecting to the shop.
I’m on a Plusnet connection with a fixed IP using Plusnet DNS
Tracert fails to the site but that’s probably the way it’s set up….
sharpecd
Errrr.... don't want to be offensive, but isn't "try https://..." a slightly silly response?
If you enter an address such as store.ee.co.uk, most browsers awill automatically assume the https form...
Champnet
Fixes: 21
@sharpecd  Should you ever set up a web site you’ll find it’s optional.
you could have 3 sites running off 1 web site name.
website.com, http://website.com, https://website.com could all point to different places.
sharpecd
Thanks for this.
tnc store.ee.co.uk -Port 443 gave this result:
WARNING: TCP connect to (62.172.48.1 : 443) failed
WARNING: Ping to 62.172.48.1 failed with status: TimedOut
ComputerName : store.ee.co.uk
RemoteAddress : 62.172.48.1
RemotePort : 443
InterfaceAlias : WiFi
SourceAddress : 192.168.1.220
PingSucceeded : False
PingReplyDetails (RTT) : 0 ms
TcpTestSucceeded : False
sharpecd
OK, thanks to Champnet for the knowledge 😊
For me I see
RemotePort       : 443
SourceAddress    : 192.168.10.100
TcpTestSucceeded : True
I do get timeouts with tracert and ping
Edit: tracert result
  1     1 ms     1 ms     1 ms  192.168.10.1
  2    10 ms     8 ms    10 ms  254.core.plus.net [195.166.130.254]
  3     9 ms    10 ms     9 ms  84.93.253.115
  4    10 ms     9 ms     9 ms  195.99.125.134
  5    10 ms    10 ms    10 ms  gre1.colindale.ukcore.bt.net [194.74.65.225]
Mustrum
Fixes: 81
On the contrary, in your OP you said you had trouble connecting to the store, using the full address works fine and eliminates any dodgy setup on your device.
sharpecd
Hi @Mustrum  - I did try the full address in my browser, it made no difference.
Just a little more info...
I tried several browsers, no change (as expected). I also tried connecting different devices - again, no change - so it's definitely something wierd on the network side of things.
I can't believe I'm the only one who has the problem.
I'd really like to get to the bottom of this, both because I like using the BT/WW store, and because it's bugging me fom a technical perspective 🤔
@sharpecd
Like @Champnet I also have a static public IP address, I suspect you have a dynamic one.
I believe there is a routing issue as you say you can connect off plusnet network, the problem is tracert and ping are not going to help as store.ee.co.uk does not respond to ping.
This needs someone from plusnet network team to investigate, sometimes a bit reluctant to tag him, he is a busy doing his day job @bobpullen can help.
Champnet
Fixes: 21
The advertised site is https://store.ee.co.uk/   I can see it but having a fixed IP the routing maybe different.
Is there anyone not on a fixed IP able to access the site ?
Champnet
Fixes: 21
@Dan_the_Van  Beat me to it, I seem to take too long to reply…….
thackie2015
I have a dynamic IP and can access the site using the posted link.
