Dsl light on but no internet
Greggus44
Since the early hours of this morning my Internet has been down , I've got a dsl connection according to the router , the phone line seems OK.
I did the text message thing and got a reply saying the line is ok, I've rebooted the router , power cycled the router, disconnected all devices and did the previous and nothing gets it back.
I'm not using a plus et router I'm using a draytek vigor 2862.
Is there anything else I can check?
5 REPLIES 5
Fixes: 558
Re: Dsl light on but no internet
What does the (WAN) log say ?
Greggus44
Logging wasn't switched on doh!
Fixes: 466
@Greggus44  Have you double checked that your settings are correct: https://www.plus.net/help/broadband/broadband-connection-settings/
Greggus44
Yep all good
Greggus44
Sorted spotted in one of the settings it was connecting the disconnecting and getting an error login details wrong , I tried to log into plusnet and same thing so reset the password and boom im back in.
