Dropouts are becoming more frequent
Madeleyite
Fixes: 6
Nothing has changed here but I am seeing more dropouts happening. See photo.
I have not touched or moved anything since my previous thread some time ago where my broadband connection was changed from 'Speed' to 'Stable' setting by Plusnet/Openreach. I expected 'Stable' to mean 'Stable' so maybe there is a developing line or hub fault? Just guessing here as I am not knowledgeable about these things.
I'll be 80 years old very shortly so don't ask me to run tests that involve me getting down on my knees, trying this, trying that etc.
Can someone run checks & tests from Plusnet's end to check if there is a fault and what it might be please?
Thank you.
12 REPLIES 12
Fixes: 353
Re: Dropouts are becoming more frequent
@Madeleyite I assume you are on FTTC? Which router are you using?
Madeleyite
Fixes: 6
Yes, FTTC and I am using the Hub Two.
Fixes: 353
Thanks. In that case can you attach a screenshot of your Technical Log - Information page and your exported event log?
Madeleyite
Fixes: 6
Before I do that do I need to redact any data that might be sensitive?
E.g. My broadband user name?
Fixes: 353
Yes, sorry - redact your username from the Technical Log. Do not modify the Event log, though.
Madeleyite
Fixes: 6
Madeleyite
Fixes: 6
Or did you mean event log? Sorry here it is.
Fixes: 353
Thanks again. Sorry, the Event Log we need is available from the page in the attachment.
Fixes: 353
It looks to me as thogh you may have a problem. I suggest you report the issue via https://www.plus.net/help/report-a-problem/ , and let us know the response.
Madeleyite
Fixes: 6
Yes I sent it 2 minutes before you asked.
Madeleyite
Fixes: 6
Okay, I'll report it using your link. Thanks.
Madeleyite
Fixes: 6
Update: -
FYI in case it helps others
I contacted the Plusnet help bot which stated that the line was operating satisfactorally but suggested I switch off the hub, wait two minutes and switch it back on again. The bot message stated that this was to 'refresh' the broadband connection?
I have waited until now to see if dropouts still happened and I am pleased to say that it is now 14 days since the last dropout.
So, 'refreshing' the connection seems to have worked.
I'll call this fixed.
