Drop Outs
JamboUnchained
Drop Outs
Hi, I've plugged my router into my master socket directly, I'm using the Plusnet 2 router, I've waited 5 mins for it to startup, and I get a connection, but I get dropouts in my connection, and for around 5 minutes I receive no connection at all, then the connection comes back online.
I'm doing everything as I'm supposed to setting up the router
what is Plusnet going to do about it?
6 REPLIES 6
Fixes: 385
Re: Drop Outs
@JamboUnchained Which type of master socket? Have you been advised your service is live?
JamboUnchained
Re: Drop Outs
i, yeah it has been live for a month or so now, but every so often i get dropouts,
my master socket is the one that is unmarked, it has no logo but it has a line through it
regards
Fixes: 385
Re: Drop Outs
OK. In that case, start with this - if you get no joy by tomorrow, come back and we can look into it further.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
JamboUnchained
Re: Drop Outs
Hi, I dont have a phone, only a mobile
its 2023 lol
Gel
Champion
Fixes: 29
Re: Drop Outs
Mustrum
Fixes: 81
Re: Drop Outs
@JamboUnchained   it might be 2023, but your broadband is delivered over a network first seen in the 1800's, and the easiest way to hear if your line is noisy and so internet slow, is a simple phone.
