Download speed up during 'open questions', down again when closed
- Download speed up during 'open questions', down ag...
Re: Download speed up during 'open questions', down again when closed
22-03-2015 12:34 AM
Extension cable - yes, broadband probably hadn't been invented when I put that in, under the carpet. It's not that long ago (only last year) that I found out about 'twisted pair' and still haven't actually seen one. What gets me, being a novice at this stuff, is that the cable that comes INTO the house from the exchange seems so feeble and rubbishy to the eye and yet its everything IN the house that seems to cause issues! I used to work for a cable making firm and we made all sorts of stuff, cable for BT as well although apart from general machining and fabrication work I did, I worked more on maintenance on braiding machines that braided cable with twisted multi cores, not the tiny solid stuff that seems to be my phone line. Earlier I took the cover off the little box outside my front door to see what's in there, and cleaned out the cobwebs and dead spiders. There were about eight or ten little wires in there and most weren't connected, just bent out of the way! It looked to me like just two blue and white ones did anything!
22-03-2015 12:39 PM
It is not usual for there to be numerous pairs from the distribution point to the house; these provide for redundancy and multiple phone lines if required. Sounds far better than the old figure of 8 drop wires!
Hopefully your SNRM reset will be done soon and you will see the maximum potential for your line.
22-03-2015 1:00 PM
24-03-2015 8:00 AM
24-03-2015 10:15 AM
24-03-2015 2:19 PM
Is the upstream capped on this line? If yes, can it be uncapped along with the SNRM reset please?
Kevin
24-03-2015 6:52 PM
25-03-2015 11:32 PM
25-03-2015 11:36 PM
Good to see that you have a result - sight of your stats would be good please?
Really good that you can see for yourself the difference between the two locations for the router.
Kevin
28-03-2015 4:39 PM
29-03-2015 9:33 PM
Link Information
Uptime: 3 days, 9:46:16
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 780 / 6.724
Data Transferred (Sent/Received) [MB/GB]: 90,07 / 1,99
Output Power (Up/Down) [dBm]: 12,2 / 20,3
Line Attenuation (Up/Down) [dB]: 23,5 / 44,0
SN Margin (Up/Down) [dB]: 5,5 / 11,3
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 27 / 0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 142 / 0
FEC Errors (Up/Down): 75.027 / 77.018
CRC Errors (Up/Down): 19 / 226
HEC Errors (Up/Down): 22 / 2.677
The results of a BT Wholesale Speed Test are as follows (I've seen better this week but maybe that's because it is Sunday night)
1. Best Effort Test: -provides background information.
Download Speed
4.71 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speed achieved during the test was - 4.71 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.93 Mbps
Upload Speed
0.46 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.46Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
And the info provided when I click on the link to see my current line speed says this....
Estimated line speed:
Current line speed:
5.9 Mb
So, basically it is looking good. Doing the 'commercial' Ookla test in the week I'd sometimes seen at least a 5.5Mbps download speed and almost a 0.6Mbps upload speed even on wi fi and even using my so-called smart TV and its clunky Safari browser. So maybe everyone is on eBay and social media on a Sunday night slowing things down a bit? I certainly used to find that effect back in the Stone Ages when I was on dial-up! So thanks very much for the help. My only concern now is what happens when I pull the plug to neaten my installation. I won't be touching it now for at least another week, and what I'm doing is running a mains extension lead under the carpet, then I will refit the standard faceplate to the BT phone socket and put the same filter back in, DSL lead one side and my telephone extensions in the other. I would think I can expect to see a drop in speeds right after but they should build up again, shouldn't they?
Cheers,
Mick.
29-03-2015 9:41 PM
30-03-2015 12:32 PM
There is still a lot to look into on your service. The change in location of the router has removed but one problem. The SNRM is somewhat higher than we would expect - we need to find out why.
Also do not confuse cable terms - the cable between the router and phone socket us the "DSL" cable, whilst that between the router and any connected device is a "LAN" or Ethernet cable.
Need to fully review this thread!
@CRT,
Has a CLT been done here please? What has the line's error history been? Is there a change coincident with the time Mick relocated the router? What is the current error rate like? Can you please post a radius plot.
Given the variation in synch speed still being seen, is a SNRM restet still premature?
What do you think?
Kevin
31-03-2015 10:55 AM
31-03-2015 3:31 PM
Thanks for these - as you say - not bad at all really! I suspect that many of the drops can be put down to Mick doing tests, relocating the router etc.
Is there any history on the line of high errors? Seeking to understand the high SNRM.
Are you happy to consider a SNRM reset please to see what Mick can get from this line with his router direct into the master socket?
Thanks,
Kevin
