Fibre broadband downstream has switched to interleave.
graham00
Been with plusnet for years and my line has always been fast up and down.  Noticed everything had gone a bit chuggish in the household and checked the router.  Line stats below.  Is there anyway to get this reset so that Im back on fastpath or am I stuck waiting for the BT algorithm.  I did upgrade my Vigor 130's  firmware recently, perhaps thats caused the issue.  Pings are substantially worse.
Any help would be appreciated.  Even knowing the cause would be a help.
Regards
Roger
  ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
   Running Mode            :      17A       State                : SHOWTIME
   DS Actual Rate          : 63307000 bps   US Actual Rate       : 20000000 bps
   DS Attainable Rate      : 73000504 bps   US Attainable Rate   : 20517320 bps
   DS Path Mode            :  Interleave    US Path Mode         :        Fast
   DS Interleave Depth     :      922       US Interleave Depth  :        1
   NE Current Attenuation  :       15 dB    Cur SNR Margin       :        3  dB
   DS actual PSD           :     6. 5 dB    US actual PSD        :     6. 7  dB
   NE CRC Count            :        0       FE CRC Count         :     2238
   NE ES Count             :        0       FE  ES Count         :     2001
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        3
   ITU Version[0]          : fe004452       ITU Version[1]       : 41590000
   VDSL Firmware Version   : 05-07-09-0F-01-07   [with Vectoring support]
   Power Management Mode   : DSL_G997_PMS_L0
   Test Mode               : DISABLE
  -------------------------------- ATU-C Info ---------------------------------
   Far Current Attenuation :       15 dB    Far SNR Margin       :        6  dB
   CO ITU Version[0]       : b5004946       CO ITU Version[1]    : 544eb206
DSLAM Chipset Vendor: IFTN
6 REPLIES 6
graham00
Re: Fibre broadband downstream has switched to interleave.
Just seems strange that a few days before those stats, my line reported with a DS Interleave depth of 1 and Path Mode as Fast.  Also connection speed was higher.
willcutforth
Fixes: 113
Around about that time did you notice your connection dropping a lot or was it the same as it has always been?
 Will Cutforth
graham00
Same as always.  Line had reset 3 times since the router had been reflashed.
I had flashed the router with a newer firmware, but I reflashed back after these issues occured.  The stats below are how it is operating back on the original firmware.
   DS Actual Rate          : 62755000 bps   US Actual Rate       : 20000000 bps
   DS Attainable Rate      : 72238312 bps   US Attainable Rate   : 20661528 bps
   DS Interleave Depth     :      914       US Interleave Depth  :        1
   NE CRC Count            :        3       FE CRC Count         :     3348
   NE ES Count             :        3       FE  ES Count         :     2997
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        1
   VDSL Firmware Version   : 05-07-06-0D-01-07   [with Vectoring support]
   Test Mode               : DISABLE
   DSLAM CHIPSET VENDOR    : < IFTN >
MatthewWheeler
Fixes: 501
Thanks for responding @graham00
Normally we're not able to reset lines to remove interleaving but there's something we can try that might have the desired effect
It should kick in from tomorrow all being well
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
graham00
Thanks Ill check tomorrow.
Again thanks for all the help.
graham00
I don't know if you tried the  change, router stats are identical to what they were before.
   DS Attainable Rate      : 72891688 bps   US Attainable Rate   : 20869782 bps
   NE CRC Count            :        7       FE CRC Count         :     3610
   NE ES Count             :        5       FE  ES Count         :     3222
   Test Mode               : DISABLE
Thanks for trying.  Just seems strange to have my line change suddenly when its been pretty solid for years.
