Download better again!
- Re: Download better again!
18-12-2009 11:09 AM
After 3.5 nudging to 4 megs download about 10 days ago, it all fell back. At that time PN & BT IP profiles showed 4000. Ticket open [ID: 31200280] & no complaint with the tech. guys. Situation seems to be improving:-
- I'm told that intermittent disconnections is my prob, although I was not aware of any.
- interleaving will be switched on [IS IT?]
- my SNR starts the day high [16] gradually drops through the day to 8/9
- this morning BT speedtester is back to IP profile 4000; had dropped back to 2500 earlier in the week
- PN is showing 3000
- D'loads @ present show BT 2.6, Speedtest 2.68, My b'band 2.68 Mb/s
Can someone please nudge the PN line speed and can anything be done about my SNR - hopefully stability & joy will be the Christmas present from PN
Many thanks, Ian
Many thanks, Ian
Message 1 of 7
(1,152 Views)
6 REPLIES 6
18-12-2009 11:15 AM
Hi Ian,
I've updated that for you now, here's hoping it either stays stable or improves for you.
Message 2 of 7
(476 Views)
18-12-2009 2:18 PM
Matt, thank you for such a speedy response. Much appreciated - I'll await & see.
Ian
Ian
Message 3 of 7
(476 Views)
18-12-2009 2:31 PM
For information, downloads have shot up significantly and indicate 3.2, 3.5 & 3.8 Mb/s using three different sources.
Grateful.
Grateful.
Message 4 of 7
(476 Views)
18-12-2009 3:56 PM
Good to hear, hope it stays like that now.
Message 5 of 7
(476 Views)
19-12-2009 7:59 AM
Well, no it unfortunately stayed like that for 12 hrs and is now back down to 2.5 or less, from 3.5 downloads. Conversely BT IP is back to 3000 from 4000. I see Support's interleaving has tripped in, following their comment 'very high number of disconnections' & 'your connection is quite erratic'.
Q. both [desk & l'top] our computers are in use throughout the day, line connection to modem/router is direct to master BT & we have not disconnected. So, what could be causing the disconnections? A minefield, I suspect!
Message 6 of 7
(476 Views)
22-12-2009 10:32 AM
Just an update on my 'very high disconnections' problem, which persistently has affected stability and download speeds.
Good help from Tech Support. Faulty modem/router identified - now replaced my Belkin N+ modem/router [new earlier in July] with the PN Thomson. Hey presto, PN tell me connection stability OK. Will now await to see now how down/loads improve & stabilise.
Lesson for me, don't place one's faith in bits of kit, even if they are new!
Message 7 of 7
(476 Views)
