Do we have another Plusnet DNS problem?
HPsauce
Aspiring Champion
Fixes: 5
Everything started degrading a little while ago, rebooting the router did nothing, but changing to Goggles DNS makes (most) things work fine.
I note that the Member Centre also seems to be down!
10 REPLIES 10
Fixes: 1,495
Re: Do we have another Plusnet DNS problem?
Member Centre is down for me too, don't use PN DNS but not seeing any other issues.
GlitterChick
Seems like it. Had an outage here too. I was sure I had added backup DNS but evidently not…
Plusnet Hub One | Software version 4.7.5.1.83.8.289.1.3 | Last updated 15/12/21
Mav
Fixes: 518
Same here using Google's DNS.
Forum Moderator and Customer
SQ2
Same here, Plusnet DNS not working on 212.159.6.9 or 212.159.13.49.  Switching to Google DNS works.
ont
I've just updated my Deco to use 4.4.4.4 and 8.8.8.8 and service is restored
HPsauce
Aspiring Champion
Fixes: 5
@dvorak I've just switched my PlusNet router to Google DNS, though a couple of my devices were set to that anyway.
Member Centre now showing a login page - eventually.
4.4.4.4 is not generally recommended as it's not a Primary. Google is 8.8.8.8 and 8.8.4.4. Cloudfare is 1.1.1.1.
briston
Called Plusnet who said they had a small DNS problem. Solved now. Small!
markhawkin
Champion
Fixes: 22
DNS problems do seem to be a bit of "a thing" with Plusnet.
Odd really as I would expect any change to DNS to be highly controlled.
breslaw
Does anyone know how to change DNS servers on a Plusnet Hub One? The settings don't seem to be editable.
I too cannot login to the Member Centre and all other authentication (email etc) fails.
GlitterChick
You can’t alter them on a Hub One. You have to add them onto as many individual devices as you can instead – and not all will allow you to do that either.
