Disable interleaving
Jaymeee
Hi
Ive recently returned to Plusnet after a mediocre experience with Zen. Very pleased to be back and have lower ping already for my gaming.
I would like to have interleaving turned off on my line please to further reduce ping and snr set to 6db. The line is pretty solid and consistent (it plods along at 47mb come rain, snow or summer!).
Many thanks
Jamie
1 REPLY 1
RealAleMadrid
Fixes: 68
Re: Disable interleaving
@Jaymeee  You must be on FTTC to get 47Mbs, the bad news is Plusnet have no way to modify any line parameters on FTTC (VDSL2) connections, it is all controlled by the automatic Openreach DLM  (dynamic line management) system. You just have wait and see if DLM makes changes.
