Devices connected to router but intermittent issues with no internet
LisaR
Hi, looking for some help with broadband connectivity issues as we seem to have exhausted all avenues with Plusnet support.
Basically, we're getting issues with devices having no internet, even though they show as being connected to broadband with full signal strength. We're seeing 'no internet' or 'server cannot be found', or 'site cannot be reached' errors on multiple devices at the same time.
We've connected a laptop directly into the ethernet port on the router and have the same issues, so we've ruled out it being just a wifi issue.
The Hub2 is all blue lights as normal and plusnet are saying there is no issue or dropout on their side and we’ve had continuous uptime for 24 hours.
We have experienced outages in the last 3 weeks, one lasting over 36hrs and I have the visuals from Plusnet to show this. Plusnet are saying this is now resolved and service is stable, but this is not what we are experiencing. It's happening so frequently it's unusable and impacting ability to work.
Any ideas/suggestions would be greatly appreciated as I'm tearing my hair out here. There's clearly something causing an issue but I'm struggling to prove to the person at the end of the phone ,and the engineers, that something is wrong.
Thanks.
20 REPLIES 20
Fixes: 303
Re: Devices connected to router but intermittent issues with no internet
@LisaR Welcome to the forums. From what you are saying above, this sounds like an internal issue to you.
To rule out one - very doubtful - possibility, can you connect the Hub to the test socket of your master socket, using a filter?
How confident are you if we need to go down some further checks?
LisaR
Thank you for the welcome Smiley
The engineer that came out yesterday changed the front panel of the master socket and removed the filter (which we still have). We've put the filter back in the line and plugged it into the test socket.
We're good to go and fairly technical if there's other things to check/try.
Lisa.
Fixes: 303
OK, @LisaR . I don't want to disturb that setup for a while, just on the off-chance that it is a socket problem, which I doubt, to be honest.
While it is being tested, however, a couple of questions - which OS is being used, especially on computers/laptops, and is your 'username' on the Hub in the form of 'yourusername@plusds'net'?
LisaR
We're still seeing perfomance issues with that set up @jab1
Device OS is a mixed bag: computers/laptops are Windows10 and macOS (Catalina & BigSur), others devices are iOS or Android.
And yep, that's the right format for the username.
We're switching back to the hub one (hub 2 was re-installed yesterday). We found that with the hub one it was reverting to orange lights when we had an issues (even though plusnet weren't seeing this as a drop on their side). Hub 2 is staying constant blue even with intermittent connection issues, so we're switching back to see if that makes a difference or gives us anything more in the event logs.
Fixes: 303
OK, Lisa, thanks for eliminating two possible easy(ish) fixes.😉
I assume you have reverted to the normal setup - Hub plugged into the DSL slot on a (presumably) 5C faceplate?
The only other simple check I can suggest at the moment is to reset the Hub (pin or similar into the rest hole on the rear until the light goes green).
Logs from the times around these issues would be good, BTW.
Fixes: 97
@jab1
I suggest exporting the event log before the Hub is factory reset as they will get erased as part of the reset process.
Dan
Fixes: 303
Good thinking, @Dan_the_Van . Hope @LisaR picks this up before the reset.😀
LisaR
Well @jab1 I picked it up before the reset, but not before we switched out the routers... 🙄
*however*, I do have logs I exported this morning, going from midnight to around 8:30am (i was seeing most of the issues around 8am this morning).
I can certainly send those and can pinpoint times when we had issues, which are linked to screenshots showing connection to router but no internet (can you tell I was trying to build out the story this morning?!)
Just need to figure out how to attach the files here.....
Fixes: 303
Lisa, to attach files, click the paperclip just outside the reply box.
LisaR
So @jab1 , slight delay in reply here as it bombed out again mid way. I've pulled and attached the event log from when we switched to this hub at 13:16 up to the latest interrupt. This is on the hubOne.
I have logs from the the Hub2 that covered most of the issues we had first thing this morning so can add these too.
LisaR
Hub2 log from this morning - sorry the formatting is a bit off with this one.
At the time of this log, Ethernet port 1 was my iMac - not sure if anything is going on with that, It wasn't scheduled to do updates.
I started trying to connect devices from 07:17 which you can see in the logs, and I have screenshots of ERR_CONNECTION_TIMED_OUT issues timed at 07:41, 07:42, 08:03, 08:10, 08:11, 08:18.
I've also attached the graphics we got from plusnet that show the recent outages and uptime.
Lisa.
Fixes: 303
Something strange going on there, @LisaR - the lease is being renewed numerous times, your machine is losing its LAN connection, and now you are getting fragmented packets.
The Hub2 logs may be interesting as well, please, but it may take @Dan_the_Van to interpret what we have/get. My thoughts are some kind of issue with the Hubs, but I can't comment easily - I'm only an amateur at this kind of thing, albeit a fairly well educated one. 😀
BTW - I like people who present evidence , instead of us having to try and drag it out of them.
Fixes: 303
From the big Radius log you provided, I suspect an issue in the BT/OR network, which may have cleared but it isn't (or wasn't) helping.
I also suspect your Mac is having problems, too.
Fixes: 97
@LisaR
do you by chance still have the original CSV file you exported from the Hub, the conversion to a PDF file has truncated some of the lines and made them hard to read.
What is the device that is connected to LAN 1
Other than the Hub Two are you using any powerline adapters and/or a second Wi-Fi access point?
From what I can see there has not been any broadband disconnects in period this log covers.
Edit: a factory reset would be a good plan.
Dan.
