Delay With Your Installation
- Re: Delay With Your Installation
yesterday
Good Morning
Few weeks ago we moved from BT (quoting £50+) to Plusnet Fibre 74 with a Plusnet Hub Two DSL.
Last week our activation was due but didnt activate, so logged in to find "We're really sorry there's been a delay with your activation" - completion date 23rd June.
The Plusnet member hub page says "It will automatically connect so you'll only have to connect your wireless devices".
I have turned the hub on this morning, I have a blue disc light, and my devices say "Connected: No Internet Access".
Can I expect this to be completed today? Or are there any settings on the hub admin I need to change?
yesterday
The migration may not have happened.
It's worth putting the BT router back and seeing if that still works.
yesterday - last edited yesterday
Didn't see this coming and it's quite annoying really.
£50 for BT was definitely excessive given I only use broadband and get over 100gb on my Giffgaff mobile plan for £12 per month. I'm no cheapskate and Plusnet wasn't my first choice but I don't have full fibre availability.
yesterday
The 23rd runs until 23:59, so it may still complete on the specified day. I've heard that it is sometimes late in the day that activation happens, presumably when some system settings are updated.
yesterday
yesterday
I suspect that for some reason your BT service is still live.
I can't see what the hold up has been given that all it will be is Openreach processing a configuration change but there seems to have been a hold up.
Assuming it was a "one touch switch" and you didn't seperately cancel BT and order Plusnet, the idea is that the old service continues until the new one starts.
I've never tried this but I suspect if you have a live BT "domestic" service you could try entering the generic BT credentials into the Plusnet Hub.
They seem to be
Username bthomehub@btbroadband.com
Password BT
I wouldn't try this until tomorrow to allow a chance for the Plusnet service to go live.
When the Plusnet service goes live you would need to reset the Plusnet hub and it should automatcally pick up the Plusnet credentials (which are not generic).
