Daily drop outs
Tim8191
Daily drop outs
Hi I am.having daily drop outs with my connection. Sometimes taking ages to reconnect. Can this get looked into please thank you
6 REPLIES 6
Fixes: 383
Re: Daily drop outs
@Tim8191 PN Help Team staff don't visit here that often these days - most of the help you get is from fellow Community members, but as we don't have access to the information PN do, a little more information is required. When did these 'drop-outs' start, how often do they occur, and what happens to your router lights when they happen ,would be a start?
Tim8191
Re: Daily drop outs
They are just random and usually reconnected within about 5 minutes. But other times it can be ages. And the hub just flashes orange.
Fixes: 383
Re: Daily drop outs
OK. Can you please supply the information requested in the below, this will give us a starting point to try and help you'
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
Re: Daily drop outs
@Tim8191
The Hub with a flashing orange light suggests there is an issue with the broadband signal to you property, a single disconnect usually recover within two minutes, however extended break could be caused by noise on the phone.
If you have a landline phone see if the line is noisy during the period when the light is flashing orange dial 17070 select option 2, the line should be clear of any noise, noise would need investigating - report a phone fault
If there is no noise the issue could be with the openreach network - report a broadband fault.
Plusnet staff may not be present on the forum over weekend but you should still be able to raise a fault following the instructions here
https://www.plus.net/help/report-a-problem/
HTH
ClaudiaG23
Fixes: 25
Re: Daily drop outs
@Tim8191 I can see that you've called in and a fault has been raised on your account, an engineer is visiting on Wednesday.
 Claudia Garner
Fixes: 383
Re: Daily drop outs
Nice when people acknowledge those that try to help.
