DSL is down
suningchen
DSL is down
Hi. Last night, my internet suddenly down. I try to reboot the router and several others, but still not work. It shows that DSL is down. All the lights is green except the internet light is dark, the internet light is flash sometimes and at that moment , it seems work. However, most of the time, the light is dark. How to solve it?
Fixes: 35
Re: DSL is down
Checks on your account show that the connection is dropping in and out very frequently, every few seconds in fact.
Diagnostic tests don't pick up on any obvious issues but do try following the checks here as your next step:
https://goo.gl/tu2WWu
If those don't help please report a fault over at http://faults.plus.net
 Adam Walker
deeplink
Re: DSL is down
I'm having exactly the same issue as this, I dont suppose you manage to find a resolution?
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: DSL is down
Intermittent connections can be caused by a wide range of factors, so a solution from one person is very unlikely to be the same for another.
Have you been through the troubleshooting and reported a fault using the links Adam provided?
 Chris Parr
 Plusnet Staff
deeplink
Re: DSL is down
Yeah, tried the troubleshooting, logged a fault but nothing found on the line. Just looking for some practical advice on what to try in the meantime.
Fixes: 35
Re: DSL is down
I've just checked your account and it looks like this has been fixed, do let us know here if you need any further help from us.
 Adam Walker
deeplink
Re: DSL is down
All sorted now, turned out to be a bad setting on the noise ratio handling.
Fixes: 35
Re: DSL is down
OK great , cheers for the heads up.
 Adam Walker
