DNS problems?
- Re: DNS problems?
Re: DNS problems?
22-03-2012 11:59 AM
Re: DNS problems?
22-03-2012 12:29 PM
Re: DNS problems?
22-03-2012 12:40 PM
Re: DNS problems?
22-03-2012 1:35 PM
Re: DNS problems?
22-03-2012 3:11 PM
Re: DNS problems?
22-03-2012 4:16 PM
Re: DNS problems?
24-03-2012 2:42 PM
Re: DNS problems?
25-03-2012 8:57 PM
I disable all my IPv6 settings on all adapters in Win 7. I also find disabling autotune and heuristic settings to improve the network throughput, but this would not help with DNS issues. I use OPEN DNS, but through manual settings, if i set my DGN3500 router to use anything other than auto, it drops the internet link.
final test option, would be to delete the Ethernet or wireless network adapter and allow a restart to re-detect it and see if a rebuild of the adapter may cure it (making sure you are using the latest driver). Keep an eye out for MS Virtual WiFi Adapter device (Show Hidden) which may cause issues -- disable to test.
Re: DNS problems?
26-03-2012 10:37 AM
No recent updates, as I said nothing at all has changed since when my connection was stable to when it's started doing this, no new software installed, no new updates installed.
Problem also occurs on my laptop with entirely different hardware and a different OS so there's absolutely 100% no doubt in my mind that this is either my router, or the actual connection itsself. Somehow I don't see it being the router as I've changed no settings and this problem never use to occur before. But apparantely my connection is "fine", atleast that's what I think (not even sure if anyone from plusnet has actually checked my connection for any abnormalities, nobody has confirmed whether they have or not, they've just said it can't be a problem with our dns servers).
Once I can check if it's the router, if I'm still having the problem then obviously it's my connection. But I was sent a DSL router which isn't compatible with my connection so I just have to wait a bit longer for a correct replacement.
Re: DNS problems?
26-03-2012 3:38 PM
I've order a fibre router for you. Let us know if this resolved your issues.
Jojo
Re: DNS problems?
26-03-2012 5:15 PM
Re: DNS problems?
31-03-2012 1:59 PM
Re: DNS problems?
02-04-2012 10:57 AM
Re: DNS problems?
19-04-2012 4:30 PM
This is now 100% undeniably an issue your side plusnet so I hope to see a fix and fast..
Not my hardware - Happens on both my W7 Desktop and XP laptop
Appeared randomly out of nowhere one day after connection was previously fine for 50+ days (stable 24/7)
Not my router - router replacement has no effect
Not any router settings or any windows settings
Tried various DNS servers (google, openDNS and more) through both Windows and Router settings page
The only possible option is a problem with my line.
Re: DNS problems?
20-04-2012 2:35 PM
Quote The only possible option is a problem with my line.
Looking at your account you did seem to disconnect at around the time of the outage yesterday and again afterwards. The the second one was probably us rebalancing the network. Following that you've been connected for over 21 hours and prior to yesterday 7 days so I don't think there's an issue.
Adam
