DNS preggers again
- DNS preggers again
Re: DNS preggers again
23-04-2009 9:59 AM
Thanks,
Richard.
23-04-2009 6:23 PM
24-04-2009 4:36 PM
The next step would probably be to start looking at traffic flows and the Ellacoyas. We made some changes recently to the traffic management setup and what people are seeing could be something to do with that.
In order for you guys to help with the diagnosis, it helps if you have an understanding about how traffic is routed to the DNS servers.
This might be above a few peoples' heads but hopefully some of you will find it useful.
There are 4 'virtual ips' that our customers use for DNS resolution, you'll probably know these by the following 4 IP addresses.
212.159.6.9
212.159.6.10
212.159.13.49
212.159.13.50
We have 2 'loadbalanced' sites that 'advertise' these IP's via OSPF. Using OSPF, traffic is pushed through our routers (e.g.pcl-gw01) to whichever site is closest to the gateway you're connected to.
The OSPF information advertised by the loadbalancers to the network just tells network routers how close they are so that a decision can be made on the closest server to route traffic – I could go into more details but it's a little beyond the scope of this thread.
e.g.
dns_request(pc/router)--->pcl-ag01--->pcl-gw01--->pcl-loadbalancer--->cache0(1-4)
This is where the problem arises because what is actually a network/routing problem can easily be misinterpreted as a DNS failure.
To help with diagnosis there are a few things that you can do when you're suffering from problems.
Firstly, find out what of the 4 DNS addresses you are using. You might already know this however if you don't you should find the information on one of your router's status pages. Failing that, you can run the ipconfig command from a Windows command prompt:
Quote from: ipconfig C:\Users\admin>ipconfig /all
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Con
nection
Physical Address. . . . . . . . . : 00-1B-77-C5-37-5E
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::6d63:2b26:cfac:4ead%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.65(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 23 April 2009 12:44:41
Lease Expires . . . . . . . . . . : 24 April 2009 12:44:41
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 212.159.13.49 <--- If this shows your router's IP address then you'll need to look on your router status pages for the addresses you're using.
212.159.13.50
NetBIOS over Tcpip. . . . . . . . : Enabled
Secondly, run a traceroute from a Windows command line to each of the DNS addresses. This will tell us both what gateway you're connected to and which of the two loadbalanced sites your DNS traffic is going to.
Quote C:\Users\admin>tracert 212.159.13.49
Tracing route to pth-cdns01.plus.net [212.159.13.49]
over a maximum of 30 hops:
1 89 ms 98 ms 99 ms dsldevice.lan [192.168.1.254]
2 58 ms 49 ms 70 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 38 ms 57 ms 36 ms ge0-0-0-504.pte-gw1.plus.net [84.92.4.89]
4 62 ms 52 ms 49 ms te2-2.pcl-gw01.plus.net [212.159.0.185]
5 84 ms 53 ms 47 ms vl63.pcl-lb01.plus.net [212.159.2.252]
6 40 ms 28 ms 31 ms pth-cdns01.plus.net [212.159.13.49]
Trace complete.
Quote C:\Users\admin>tracert 212.159.13.50
Tracing route to pth-cdns02.plus.net [212.159.13.50]
1 75 ms 99 ms 98 ms dsldevice.lan [192.168.1.254]
2 68 ms 49 ms 55 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 72 ms 48 ms 66 ms ge0-0-0-504.pte-gw1.plus.net [84.92.4.89]
4 64 ms 52 ms 48 ms te2-2.pcl-gw01.plus.net [212.159.0.185]
5 30 ms 233 ms 30 ms vl63.pcl-lb01.plus.net [212.159.2.252]
6 271 ms 281 ms 60 ms pth-cdns02.plus.net [212.159.13.50]
Trace complete.
Finally try performing a DNS lookup against each of the DNS addresses using a command line utility like 'nslookup'
Quote C:\Users\admin>nslookup bbc.co.uk 212.159.13.49
Server: pth-cdns01.plus.net
Address: 212.159.13.49
Non-authoritative answer:
Address: 212.58.254.252
Quote C:\Users\admin>nslookup bbc.co.uk 212.159.13.50
Server: pth-cdns02.plus.net
Address: 212.159.13.50
The next time any of you are having problems, try some of the steps above and post your findings back here.
24-04-2009 4:44 PM
thats if any other isp would even investigate such a problem.
i've allways used 212.159.13.49 212.159.13.50 ip's and as i havent seen any problems i will switch to the other ip's and see if theres any diffrence beetween the pair
28-04-2009 10:22 PM
My tests tonight...
Router DNS set to 212.159.6.9
Quote Traceroute has started ...
traceroute to 212.159.6.9 (212.159.6.9), 64 hops max, 40 byte packets
1 10.0.0.1 (10.0.0.1) 2.014 ms 0.983 ms 0.924 ms
2 lo0-plusnet.pcl-ag02.plus.net (195.166.128.39) 25.105 ms 19.613 ms 22.932 ms
3 gi1-2-904.pcl-gw02.plus.net (84.92.0.141) 23.305 ms 18.493 ms 19.817 ms
4 * * *
5 * * *
6 * * *
7 *
traceroute to 212.159.6.10 (212.159.6.10), 64 hops max, 40 byte packets
1 10.0.0.1 (10.0.0.1) 1.232 ms 1.557 ms 1.058 ms
2 lo0-plusnet.pcl-ag02.plus.net (195.166.128.39) 23.022 ms 21.519 ms 22.925 ms
3 gi1-2-904.pcl-gw02.plus.net (84.92.0.141) 25.136 ms 24.203 ms 27.048 ms
4 * * *
5 * * *
6 * * *
7 *
traceroute to 212.159.13.49 (212.159.13.49), 64 hops max, 40 byte packets
1 10.0.0.1 (10.0.0.1) 2.371 ms 0.938 ms 0.912 ms
2 lo0-plusnet.pcl-ag02.plus.net (195.166.128.39) 33.771 ms 20.808 ms 21.620 ms
3 gi1-2-904.pcl-gw02.plus.net (84.92.0.141) 24.036 ms 22.213 ms 26.468 ms
4 * * *
5 * * *
6 * * *
traceroute to 212.159.13.50 (212.159.13.50), 64 hops max, 40 byte packets
1 10.0.0.1 (10.0.0.1) 1.284 ms 1.078 ms 1.033 ms
2 lo0-plusnet.pcl-ag02.plus.net (195.166.128.39) 26.907 ms 19.805 ms 30.467 ms
3 gi1-2-904.pcl-gw02.plus.net (84.92.0.141) 60.402 ms 25.330 ms 22.245 ms
4 * * *
5 * * *
6 * *
Quote Macintosh:~ gurth$ nslookup bbc.co.uk 212.159.6.9
Server: 212.159.6.9
Address: 212.159.6.9#53
Quote Macintosh:~ gurth$ nslookup bbc.co.uk 212.159.6.10
Server: 212.159.6.10
Address: 212.159.6.10#53
Quote Macintosh:~ gurth$ nslookup bbc.co.uk 212.159.13.49
Server: 212.159.13.49
Address: 212.159.13.49#53
Quote slookup bbc.co.uk 212.159.13.50
Server: 212.159.13.50
Address: 212.159.13.50#53
Quote Macintosh:~ gurth$ traceroute bbc.co.uk
traceroute to bbc.co.uk (212.58.254.252), 64 hops max, 40 byte packets
1 10.0.0.1 (10.0.0.1) 1.812 ms 1.029 ms 1.200 ms
2 lo0-plusnet.pcl-ag02.plus.net (195.166.128.39) 20.153 ms 32.217 ms 23.306 ms
3 gi1-2-904.pcl-gw02.plus.net (84.92.0.141) 22.344 ms 38.864 ms 19.937 ms
4 te2-2.thn-gw2.plus.net (212.159.0.190) 99.340 ms 219.893 ms 205.630 ms
5 rt0.thdo.bbc.co.uk (212.58.239.25) 45.047 ms 46.175 ms 28.850 ms
6 212.58.238.133 (212.58.238.133) 43.631 ms 23.760 ms 25.222 ms
7 rdirslb0.thdo.bbc.co.uk (212.58.224.136) 31.709 ms 22.821 ms 25.399 ms
8 virtual3.rbsov.bbc.co.uk (212.58.254.252) 34.048 ms 23.892 ms 21.338 ms
28-04-2009 10:44 PM
Quote Macintosh:sbin gurth$ traceroute bbc.co.uk
1 10.0.0.1 (10.0.0.1) 1.515 ms 1.019 ms 1.328 ms
2 lo0-plusnet.pcl-ag02.plus.net (195.166.128.39) 29.316 ms 29.277 ms 33.768 ms
3 * gi1-2-904.pcl-gw02.plus.net (84.92.0.141) 31.224 ms 29.474 ms
4 te2-2.thn-gw2.plus.net (212.159.0.190) 27.929 ms 32.769 ms 43.779 ms
5 rt0.thdo.bbc.co.uk (212.58.239.25) 26.585 ms 21.885 ms 26.789 ms
6 212.58.238.133 (212.58.238.133) 28.601 ms 26.928 ms 24.039 ms
7 rdirslb0.thdo.bbc.co.uk (212.58.224.136) 20.783 ms 24.472 ms 42.663 ms
8 virtual3.rbsov.bbc.co.uk (212.58.254.252) 37.693 ms 57.068 ms 38.298 ms
28-04-2009 11:54 PM
(left my user-agent switched to IE6 but shouldn't matter)
START - Date: Tue, 28 Apr 2009 22:49:17 GMT
END - Date: Tue, 28 Apr 2009 22:49:54 GMT
Takes 37 seconds to load the home page.
Quote http://www.facebook.com/
GET / HTTP/1.1
Host: www.facebook.com
User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1)
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-us,en;q=0.5
Accept-Encoding: gzip,deflate
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive: 300
Connection: keep-alive
HTTP/1.x 200 OK
Server: Apache/1.3.41.fb2
P3P: CP="HONK"
Set-Cookie: datr=1240958958-67b0462dd76e5e4bc27577577170d58750aa610724101bc7be546; expires=Thu, 28-Apr-2011 22:49:18 GMT; path=/; domain=.facebook.com; httponly
Set-Cookie: reg_fb_gate=http%3A%2F%2Fwww.facebook.com%2F; path=/; domain=.facebook.com
Set-Cookie: reg_fb_ref=http%3A%2F%2Fwww.facebook.com%2F; path=/; domain=.facebook.com
Set-Cookie: ABT=%3A%3A%23b0ad8a8df29cc7bafdf91e67c86d58561st0%3A1241563758%3AA; expires=Tue, 05-May-2009 22:49:18 GMT; path=/; domain=.facebook.com; httponly
Set-Cookie: test_cookie=1; path=/; domain=.facebook.com
Set-Cookie: login=+; path=/; domain=.facebook.com; httponly
Expires: Mon, 26 Jul 1997 05:00:00 GMT
Cache-Control: private, no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
X-Cnection: close
Transfer-Encoding: chunked
Content-Type: text/html; charset=utf-8
Content-Encoding: gzip
http://static.ak.fbcdn.net/js_strings.php/t86177/en_US
GET /js_strings.php/t86177/en_US HTTP/1.1
Host: static.ak.fbcdn.net
Accept: */*
Keep-Alive: 300
Referer: http://www.facebook.com/
HTTP/1.x 200 OK
Server: Apache/1.3.41.fb1
X-Cnection: close
Content-Type: application/x-javascript; charset=utf-8
Content-Length: 25795
Vary: Accept-Encoding
Cache-Control: public, max-age=7678
Expires: Wed, 29 Apr 2009 00:57:20 GMT
Date: Tue, 28 Apr 2009 22:49:22 GMT
http://b.static.ak.fbcdn.net/rsrc.php/z93A6/lpkg/8ahydx9t/en_US/141/160683/js/6a1bbnrfz64os8cc.pkg.j...
GET /rsrc.php/z93A6/lpkg/8ahydx9t/en_US/141/160683/js/6a1bbnrfz64os8cc.pkg.js HTTP/1.1
Host: b.static.ak.fbcdn.net
Accept: */*
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.139.107" PID="5497"
X-Gen-Date: Mon, 27 Apr 2009 23:15:57 +0000
X-Cnection: close
Content-Length: 66392
Cache-Control: public, max-age=2334311
Expires: Mon, 25 May 2009 23:14:39 GMT
Date: Tue, 28 Apr 2009 22:49:28 GMT
http://static.ak.fbcdn.net/rsrc.php/zEGHC/lpkg/a64xkkxk/nu_ll/141/159520/js/994qn6krufc48gok.pkg.js
GET /rsrc.php/zEGHC/lpkg/a64xkkxk/nu_ll/141/159520/js/994qn6krufc48gok.pkg.js HTTP/1.1
Accept: */*
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.140.101" PID="19914"
X-Gen-Date: Tue, 21 Apr 2009 18:38:35 +0000
X-Cnection: close
Content-Length: 11532
Cache-Control: public, max-age=1799347
Expires: Tue, 19 May 2009 18:38:47 GMT
Date: Tue, 28 Apr 2009 22:49:40 GMT
http://static.ak.fbcdn.net/rsrc.php/zEWNT/lpkg/psg1kyu7/en_US/141/159678/js/3xqcncv2s4g0804o.pkg.js
GET /rsrc.php/zEWNT/lpkg/psg1kyu7/en_US/141/159678/js/3xqcncv2s4g0804o.pkg.js HTTP/1.1
Accept: */*
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.140.110" PID="31431"
X-Gen-Date: Wed, 22 Apr 2009 03:30:22 +0000
X-Cnection: close
Content-Length: 16740
Cache-Control: public, max-age=1831245
Expires: Wed, 20 May 2009 03:30:25 GMT
http://b.static.ak.fbcdn.net/rsrc.php/zEJTV/l/5k5jekhg/nu_ll/139152/js/useragent.js
GET /rsrc.php/zEJTV/l/5k5jekhg/nu_ll/139152/js/useragent.js HTTP/1.1
Accept: */*
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.140.110" PID="3750"
X-Gen-Date: Thu, 16 Apr 2009 12:37:59 +0000
X-Cnection: close
Content-Length: 486
Cache-Control: public, max-age=1345679
Expires: Thu, 14 May 2009 12:37:39 GMT
http://b.static.ak.fbcdn.net/rsrc.php/zC6TQ/l/b5pdlfqn/en_US/149980/css/UIErrorFlag.css
GET /rsrc.php/zC6TQ/l/b5pdlfqn/en_US/149980/css/UIErrorFlag.css HTTP/1.1
Accept: text/css,*/*;q=0.1
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.139.104" PID="8167"
X-Gen-Date: Sat, 11 Apr 2009 21:31:51 +0000
X-Cnection: close
Content-Type: text/css; charset=utf-8
Content-Length: 760
Cache-Control: public, max-age=945700
Expires: Sat, 09 May 2009 21:31:20 GMT
http://b.static.ak.fbcdn.net/images/loaders/indicator_blue_small.gif?8:111099
GET /images/loaders/indicator_blue_small.gif?8:111099 HTTP/1.1
Accept: image/png,image/*;q=0.8,*/*;q=0.5
Keep-Alive: 300
HTTP/1.x 200 OK
Last-Modified: Tue, 14 Apr 2009 01:47:51 GMT
Accept-Ranges: bytes
Content-Length: 522
X-Cnection: close
Content-Type: image/gif
Cache-Control: max-age=1435768
Expires: Fri, 15 May 2009 13:39:08 GMT
http://static.ak.fbcdn.net/rsrc.php/z96MF/lpkg/42sa3msb/en_US/141/159058/css/avqf3zq4sh4o4gg8.pkg.cs...
GET /rsrc.php/z96MF/lpkg/42sa3msb/en_US/141/159058/css/avqf3zq4sh4o4gg8.pkg.css HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.140.102" PID="4476"
X-Gen-Date: Tue, 21 Apr 2009 17:05:20 +0000
X-Cnection: close
Content-Length: 3147
Cache-Control: public, max-age=1793717
Expires: Tue, 19 May 2009 17:04:57 GMT
http://static.ak.fbcdn.net/rsrc.php/zBNIU/lpkg/24zuuo0c/en_US/141/156927/css/8miun4q7u6cko4os.pkg.cs...
GET /rsrc.php/zBNIU/lpkg/24zuuo0c/en_US/141/156927/css/8miun4q7u6cko4os.pkg.css HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.140.108" PID="18714"
X-Gen-Date: Tue, 14 Apr 2009 16:53:28 +0000
X-Cnection: close
Content-Length: 3881
Cache-Control: public, max-age=1188204
Expires: Tue, 12 May 2009 16:53:04 GMT
http://static.ak.fbcdn.net/rsrc.php/z9H1R/l/4hiewybl/nu_ll/158955/js/language.js
GET /rsrc.php/z9H1R/l/4hiewybl/nu_ll/158955/js/language.js HTTP/1.1
Accept: */*
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.140.110" PID="31090"
X-Gen-Date: Tue, 21 Apr 2009 17:05:16 +0000
X-Cnection: close
Content-Length: 500
Cache-Control: public, max-age=1793756
Expires: Tue, 19 May 2009 17:05:36 GMT
http://b.static.ak.fbcdn.net/rsrc.php/z1NGP/lpkg/59i9oy5i/en_US/141/159927/css/1uom3yh8tp7o4so4.pkg....
GET /rsrc.php/z1NGP/lpkg/59i9oy5i/en_US/141/159927/css/1uom3yh8tp7o4so4.pkg.css HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.139.103" PID="3578"
X-Gen-Date: Thu, 23 Apr 2009 00:43:31 +0000
X-Cnection: close
Content-Length: 12027
Cache-Control: public, max-age=1907592
Expires: Thu, 21 May 2009 00:42:52 GMT
http://static.ak.fbcdn.net/favicon.ico?8:132011
GET /favicon.ico?8:132011 HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
Last-Modified: Tue, 14 Apr 2009 01:48:01 GMT
Content-Length: 1150
X-Cnection: close
Content-Type: image/x-icon
Cache-Control: max-age=1435757
Expires: Fri, 15 May 2009 13:38:58 GMT
Date: Tue, 28 Apr 2009 22:49:41 GMT
Keep-Alive: 300
HTTP/1.x 200 OK
Content-Length: 522
X-Cnection: close
http://b.static.ak.fbcdn.net/rsrc.php/z1FZ6/lpkg/2b37kcqn/en_US/141/160683/js/2wbl1xghlbcw44wc.pkg.j...
GET /rsrc.php/z1FZ6/lpkg/2b37kcqn/en_US/141/160683/js/2wbl1xghlbcw44wc.pkg.js HTTP/1.1
Accept: */*
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.139.108" PID="22487"
X-Gen-Date: Mon, 27 Apr 2009 23:16:20 +0000
X-Cnection: close
Content-Length: 8552
Cache-Control: public, max-age=2334443
Expires: Mon, 25 May 2009 23:17:03 GMT
Keep-Alive: 300
HTTP/1.x 200 OK
Content-Length: 522
X-Cnection: close
http://static.ak.fbcdn.net/images/spacer.gif?8:11
GET /images/spacer.gif?8:11 HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
Last-Modified: Tue, 14 Apr 2009 01:47:57 GMT
Content-Length: 67
X-Cnection: close
Cache-Control: max-age=1435698
Expires: Fri, 15 May 2009 13:38:00 GMT
Date: Tue, 28 Apr 2009 22:49:42 GMT
http://b.static.ak.fbcdn.net/rsrc.php/zD80L/lpkg/9iejmmzn/en_US/141/160683/css/1zyeeo7k8o0088kg.pkg....
GET /rsrc.php/zD80L/lpkg/9iejmmzn/en_US/141/160683/css/1zyeeo7k8o0088kg.pkg.css HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.140.109" PID="21461"
X-Gen-Date: Mon, 27 Apr 2009 23:15:59 +0000
X-Cnection: close
Content-Length: 5016
Cache-Control: public, max-age=2334385
Expires: Mon, 25 May 2009 23:16:05 GMT
http://static.ak.fbcdn.net/rsrc.php/zE51T/lpkg/8669a2b0/en_US/141/160683/css/a264p1a9cnscssok.pkg.cs...
GET /rsrc.php/zE51T/lpkg/8669a2b0/en_US/141/160683/css/a264p1a9cnscssok.pkg.css HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.140.101" PID="30949"
X-Cnection: close
Content-Length: 5428
Cache-Control: public, max-age=2334355
Expires: Mon, 25 May 2009 23:15:44 GMT
Date: Tue, 28 Apr 2009 22:49:49 GMT
http://b.static.ak.fbcdn.net/images/menubar/signup_callout.png
GET /images/menubar/signup_callout.png HTTP/1.1
Keep-Alive: 300
Referer: http://b.static.ak.fbcdn.net/rsrc.php/zD80L/lpkg/9iejmmzn/en_US/141/160683/css/1zyeeo7k8o0088kg.pkg....
HTTP/1.x 200 OK
Last-Modified: Thu, 16 Apr 2009 01:26:05 GMT
Content-Length: 2287
X-Cnection: close
Content-Type: image/png
Cache-Control: max-age=1345705
Expires: Thu, 14 May 2009 12:38:19 GMT
http://static.ak.fbcdn.net/images/welcome/radial_behind_content.jpg
GET /images/welcome/radial_behind_content.jpg HTTP/1.1
Keep-Alive: 300
Referer: http://static.ak.fbcdn.net/rsrc.php/zBNIU/lpkg/24zuuo0c/en_US/141/156927/css/8miun4q7u6cko4os.pkg.cs...
HTTP/1.x 200 OK
Last-Modified: Thu, 16 Apr 2009 01:26:06 GMT
Content-Length: 8973
X-Cnection: close
Content-Type: image/jpeg
Cache-Control: max-age=1345769
Expires: Thu, 14 May 2009 12:39:23 GMT
http://static.ak.fbcdn.net/images/welcome/welcome_page_map.png
GET /images/welcome/welcome_page_map.png HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
Content-Length: 42629
X-Cnection: close
Cache-Control: max-age=1345702
Expires: Thu, 14 May 2009 12:38:16 GMT
http://static.ak.fbcdn.net/rsrc.php/z7W15/h/f4hqz9q8/images/sprite/icons_ie6.gif
GET /rsrc.php/z7W15/h/f4hqz9q8/images/sprite/icons_ie6.gif HTTP/1.1
Keep-Alive: 300
Referer: http://static.ak.fbcdn.net/rsrc.php/zE51T/lpkg/8669a2b0/en_US/141/160683/css/a264p1a9cnscssok.pkg.cs...
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.140.109" PID="3032"
X-Gen-Date: Fri, 17 Apr 2009 23:57:44 +0000
Content-Length: 15437
X-Cnection: close
Cache-Control: public, max-age=1472889
Expires: Fri, 15 May 2009 23:58:03 GMT
http://b.static.ak.fbcdn.net/images/menubar/fb_menubar_background.gif
GET /images/menubar/fb_menubar_background.gif HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
Content-Length: 928
X-Cnection: close
Cache-Control: max-age=1345747
Expires: Thu, 14 May 2009 12:39:01 GMT
http://b.static.ak.fbcdn.net/rsrc.php/zAW2X/l/2m2ptflm/en_US/159868/js/recaptcha_ajax.js
GET /rsrc.php/zAW2X/l/2m2ptflm/en_US/159868/js/recaptcha_ajax.js HTTP/1.1
Accept: */*
Keep-Alive: 300
HTTP/1.x 200 OK
X-Debug-Info: ServerIP="10.16.139.107" PID="8485"
X-Gen-Date: Wed, 22 Apr 2009 22:55:51 +0000
X-Cnection: close
Content-Length: 3935
Cache-Control: public, max-age=1901147
Expires: Wed, 20 May 2009 22:55:27 GMT
http://b.static.ak.fbcdn.net/images/menubar/fb_menubar_logo_big.gif
GET /images/menubar/fb_menubar_logo_big.gif HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
Content-Length: 2704
X-Cnection: close
Cache-Control: max-age=1345663
Expires: Thu, 14 May 2009 12:37:37 GMT
http://static.ak.fbcdn.net/images/welcome/linear_tile.jpg
GET /images/welcome/linear_tile.jpg HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
Content-Length: 938
X-Cnection: close
Cache-Control: max-age=1345685
Expires: Thu, 14 May 2009 12:37:59 GMT
http://static.ak.fbcdn.net/images/welcome/linear_shim.png
GET /images/welcome/linear_shim.png HTTP/1.1
Keep-Alive: 300
HTTP/1.x 200 OK
Content-Length: 141
X-Cnection: close
Cache-Control: max-age=1345694
Expires: Thu, 14 May 2009 12:38:08 GMT
29-04-2009 11:51 AM
Quote Domain Name Server 212.159.6.9
212.159.6.10
Quote C:\Documents and Settings\wibble>tracert 212.159.6.9
Tracing route to ptn-cdns01.plus.net [212.159.6.9]
1 <1 ms <1 ms <1 ms www.routerlogin.com [192.168.101.1]
2 40 ms 39 ms 38 ms lo0-homesurf.pcl-ag03.plus.net [195.166.128.110]
3 38 ms 39 ms 38 ms gi1-7-706.pcl-gw02.plus.net [84.92.0.193]
4 39 ms 39 ms 39 ms vl63.pcl-lb01.plus.net [212.159.2.252]
5 39 ms 39 ms 40 ms ptn-cdns01.plus.net [212.159.6.9]
Trace complete.
C:\Documents and Settings\wibble>tracert 212.159.6.10
Tracing route to ptn-cdns02.plus.net [212.159.6.10]
2 39 ms 38 ms 38 ms lo0-homesurf.pcl-ag03.plus.net [195.166.128.110]
3 83 ms 222 ms 182 ms gi1-7-706.pcl-gw02.plus.net [84.92.0.193]
4 39 ms 39 ms 38 ms vl63.pcl-lb01.plus.net [212.159.2.252]
5 39 ms 41 ms 39 ms ptn-cdns02.plus.net [212.159.6.10]
Trace complete.
C:\Documents and Settings\wibble>tracert 212.159.13.49
2 47 ms 39 ms 39 ms lo0-homesurf.pcl-ag03.plus.net [195.166.128.110]
4 49 ms 49 ms 50 ms vl63.pcl-lb01.plus.net [212.159.2.252]
5 53 ms 43 ms 40 ms pth-cdns01.plus.net [212.159.13.49]
Trace complete.
C:\Documents and Settings\wibble>tracert 212.159.13.50
2 40 ms 39 ms 39 ms lo0-homesurf.pcl-ag03.plus.net [195.166.128.110]
3 39 ms 38 ms 38 ms gi1-7-706.pcl-gw02.plus.net [84.92.0.193]
4 39 ms 40 ms 39 ms vl63.pcl-lb01.plus.net [212.159.2.252]
5 38 ms 38 ms 39 ms pth-cdns02.plus.net [212.159.13.50]
Trace complete.
Quote C:\Documents and Settings\wibble>nslookup mail.google.com 212.159.6.9
Server: ptn-cdns01.plus.net
Addresses: 209.85.137.18, 209.85.137.19, 209.85.137.83
Aliases: mail.google.com
C:\Documents and Settings\wibble>nslookup mail.google.com 212.159.6.10
Server: ptn-cdns02.plus.net
Addresses: 209.85.137.19, 209.85.137.83, 209.85.137.18
C:\Documents and Settings\wibble>nslookup mail.google.com 212.159.13.49
Addresses: 209.85.137.83, 209.85.137.18, 209.85.137.19
C:\Documents and Settings\wibble>nslookup mail.google.com 212.159.13.50
Addresses: 74.125.39.83, 74.125.39.17, 74.125.39.18, 74.125.39.19
29-04-2009 3:23 PM
Primary DNS Server 212.159.6.10 Secondary DNS Server 212.159.6.9
Default Gateway 195.166.128.110 (pcl-ag03)
tracert www.ask.com
Tracing route to a1230.b.akamai.net [80.157.169.137]
1 3 ms 2 ms 2 ms voyager.home [192.168.1.1]
2 37 ms 36 ms 40 ms lo0-homesurf.pcl-ag03.plus.net [195.166.128.110]
3 37 ms 34 ms 37 ms gi1-7-706.pcl-gw02.plus.net [84.92.0.193]
4 38 ms 39 ms 36 ms te2-1.pcl-gw01.plus.net [212.159.1.113]
5 39 ms 36 ms 37 ms xe-1-2-0-0.lon20.ip.tiscali.net [213.200.79.233]
6 39 ms 38 ms 37 ms ge-1-1-0.lon22.ip.tiscali.net [89.149.186.78]
7 59 ms 39 ms 37 ms 62.156.139.213
8 35 ms 40 ms 35 ms 194.25.6.193
9 37 ms 39 ms 38 ms a1230.b.akamai.net [80.157.169.137]
Trace complete.
I've never done a tracert on "Ask" before. Shock, so is this why it takes so long to load compared to Google, as it's served by akamai - it's the damn traffic management
Tracing route to google.co.uk [216.239.59.104]
2 39 ms 38 ms 41 ms lo0-homesurf.pcl-ag03.plus.net [195.166.128.110]
3 40 ms 40 ms 36 ms gi1-7-706.pcl-gw02.plus.net [84.92.0.193]
4 36 ms 36 ms 37 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 40 ms 40 ms 36 ms vl23.pte-gw2.plus.net [212.159.4.28]
6 42 ms 38 ms 38 ms 195.66.224.125
7 87 ms 39 ms 41 ms 209.85.252.40
8 51 ms 50 ms 52 ms 209.85.251.190
9 51 ms 54 ms 55 ms 64.233.174.185
10 57 ms 53 ms 56 ms 216.239.49.126
11 51 ms 52 ms 52 ms google.co.uk [216.239.59.104]
Trace complete.
I'm beginning to think that this traffic management has gone totally overboard.
29-04-2009 3:58 PM
29-04-2009 4:00 PM
Quote from: Anotherone I'm beginning to think that this traffic management has gone totally overboard.
I've been wondering that too, considering that gurth's examples earlier - BBC and Facebook - both also use Akamai.
29-04-2009 4:12 PM
It's pretty chuggy on my O2 connection.
29-04-2009 5:38 PM
Just fired up http://www.bbc.co.uk/iplayer/ and its zipped into life, started streaming fine so hopefully things will be sorted for me now on. If performance dips again I'll run some more test.
Thank you for keeping the issue open and investigating.
29-04-2009 5:57 PM
Quote from: thehatman Very slow, strangulated page loading here again. Definitely a continuing problem. Awful. Reminds me of dial up.
This is what im getting, but only late evenings it seems.
29-04-2009 9:25 PM
i just check......my DNS...
My Netgear DG834G ....i can see DNS was 212.159.6.10 & 212.159.6.9
AND
My connection setting at Plusnet Website..i can see DNS was 212.159.13.49 & 212.159.13.50
i wonder is it should same both DNS or doesnt matter?
