DNS preggers again
- DNS preggers again
Re: DNS preggers again
30-04-2009 1:08 PM
30-04-2009 8:02 PM
Quote Redirect Loop
Redirection limit for this URL exceeded. Unable to load the requested page. This may be caused by cookies that are blocked.
The browser has stopped trying to retrieve the requested item. The site is redirecting the request in a way that will never complete.
* Have you disabled or blocked cookies required by this site?
* NOTE: If accepting the site's cookies does not resolve the problem, it is probably a server configuration issue and not your computer.
Are these problems to do with the DNS problems at Plusnet?
30-04-2009 8:23 PM
30-04-2009 8:23 PM
http://downforeveryoneorjustme.com/http://www.confused.com/home/form
delete this post mr speedy
30-04-2009 8:27 PM
Quote from: Oldjim Nope the problem is the site http://downforeveryoneorjustme.com/confused.com/home/form
Thanks for that.
I've been having other random non-loading in pages in IE8, should I change my DNS servers and is there and idiots guide to how to do it?
30-04-2009 8:31 PM
Not likely - it shows us old un's can sometimes type faster than you young whippersnappers
Quote from: ASBO delete this post mr speedy
30-04-2009 8:59 PM
30-04-2009 9:02 PM
Quote from: rammie1976
Thanks for that.
You shouldn't need to change your DNS servers. Despite the title of this thread we're of the opinion that the intermittent connectivity issues of late have actually been down to our traffic management switches. If that is the case then there's a good possibility you'd be affected even if you were using third party DNS servers as *all* of your traffic passes through these switches.
We reloaded them all earlier today though so I'm interested to hear whether or not things get better over the coming days.
jim:green code tags fixed mod:end
30-04-2009 9:04 PM
30-04-2009 9:05 PM
30-04-2009 10:02 PM
01-05-2009 3:53 PM
01-05-2009 4:06 PM
Quote from: Liam Getting intermittently slow returns to DNS requests and occasional timeouts here again.
Im really not convinced this is a DNS issue, as users who use opendns suffer the same problem. If any one has these problems please provide some trace routes and times etc during the event.
Bob has posted previously on what to do
Russ
01-05-2009 7:14 PM
Quote from: Bob
Thanks for that.
I think that some of the problem was down to IE8 - I have (hopefully) fixed new tabbed pages not loading using the advice here.
01-05-2009 7:39 PM
Quote from: RustyNetworks
Russ
Getting strange results on a ping -t. Because it is intermittent in nature it'll not respond or take a long time one time, then try it a second later and it'll work. But it keeps doing it. On a ping -t the latency to it just keeps shooting up to 140ms+ every now and then. I get better latency to the US normally.
Quote Reply from 212.159.13.49: bytes=32 time=25ms TTL=252
Reply from 212.159.13.49: bytes=32 time=33ms TTL=252
Reply from 212.159.13.49: bytes=32 time=31ms TTL=252
Reply from 212.159.13.49: bytes=32 time=24ms TTL=252
Reply from 212.159.13.49: bytes=32 time=37ms TTL=252
Reply from 212.159.13.49: bytes=32 time=22ms TTL=252
Reply from 212.159.13.49: bytes=32 time=21ms TTL=252
Reply from 212.159.13.49: bytes=32 time=23ms TTL=252
Reply from 212.159.13.49: bytes=32 time=30ms TTL=252
Reply from 212.159.13.49: bytes=32 time=26ms TTL=252
Reply from 212.159.13.49: bytes=32 time=27ms TTL=252
Reply from 212.159.13.49: bytes=32 time=28ms TTL=252
Reply from 212.159.13.49: bytes=32 time=29ms TTL=252
Reply from 212.159.13.49: bytes=32 time=36ms TTL=252
Reply from 212.159.13.49: bytes=32 time=20ms TTL=252
Reply from 212.159.13.49: bytes=32 time=19ms TTL=252
Reply from 212.159.13.49: bytes=32 time=46ms TTL=252
Reply from 212.159.13.49: bytes=32 time=129ms TTL=252
Reply from 212.159.13.49: bytes=32 time=115ms TTL=252
Reply from 212.159.13.49: bytes=32 time=49ms TTL=252
Reply from 212.159.13.49: bytes=32 time=67ms TTL=252
Reply from 212.159.13.49: bytes=32 time=54ms TTL=252
Reply from 212.159.13.49: bytes=32 time=38ms TTL=252
Reply from 212.159.13.49: bytes=32 time=32ms TTL=252
Reply from 212.159.13.49: bytes=32 time=79ms TTL=252
Reply from 212.159.13.49: bytes=32 time=34ms TTL=252
Reply from 212.159.13.49: bytes=32 time=117ms TTL=252
Reply from 212.159.13.49: bytes=32 time=59ms TTL=252
Reply from 212.159.13.49: bytes=32 time=45ms TTL=252
Reply from 212.159.13.49: bytes=32 time=56ms TTL=252
Reply from 212.159.13.49: bytes=32 time=43ms TTL=252
Reply from 212.159.13.49: bytes=32 time=47ms TTL=252
Reply from 212.159.13.49: bytes=32 time=81ms TTL=252
Reply from 212.159.13.49: bytes=32 time=65ms TTL=252
Reply from 212.159.13.49: bytes=32 time=35ms TTL=252
Reply from 212.159.13.49: bytes=32 time=42ms TTL=252
Reply from 212.159.13.49: bytes=32 time=39ms TTL=252
Reply from 212.159.13.49: bytes=32 time=44ms TTL=252
Reply from 212.159.13.49: bytes=32 time=50ms TTL=252
Reply from 212.159.13.49: bytes=32 time=40ms TTL=252
Reply from 212.159.13.49: bytes=32 time=58ms TTL=252
Reply from 212.159.13.49: bytes=32 time=142ms TTL=252
Reply from 212.159.13.49: bytes=32 time=131ms TTL=252
Reply from 212.159.13.49: bytes=32 time=125ms TTL=252
Reply from 212.159.13.49: bytes=32 time=159ms TTL=252
