DNS Server settings FullFibre 500
d8smt
HI all,
wondering what the default DNS server settings are for the FullFibre 500 service (I also have a static IP).
I know about the Google DNS (and others) but wondering specifically about the PlusNet ones. Currently it seems to have autopopulated with:
Default Gateway: 195.166.130.249
Primary DNS Server: 212.159.13.49
Secondary DNS Server: 212.159.6.9
Are these correct ?
And no, these aren't through a Hub2 (I've given up with that weeks ago) but copied from my original Hub2 supplied with the Full fibre upgrade
cheers
Dave
5 REPLIES 5
Fixes: 577
Re: DNS Server settings FullFibre 500
They look fine to me.
Fixes: 146
There are four, the other two are 212.159.13.50 and 212.159.6.10
HTH
d8smt
Many thanks, that explains the difference. tbh they're not easy to find in the help menus of the PlusNet site, and my previous broadband was on the x.x.6.x address range.
@d8smt wrote:
... not easy to find in the help menus of the PlusNet site
The main Plusnet site, and this forum are pretty difficult to navigate, or find what you're looking for with the built in 'search'
I always Google "plus.net" and what I'm looking for, and usually find the answer immediately.
