DLink Router
- DLink Router
- « Previous
- 1
- 2
- Next »
Re: DLink Router
04-05-2010 10:53 AM
Been through loads of routers and vast majority of cases it is the wireless that goes but the ethernet ports are OK. Keep these routers and turn off the wireless and either start putting cabling through your house (I use that flat ethernet cable that can go under carpets) or buy the much more robust Airport Express to plug into it like I do - you will never go back to wireless routers again! plus you can stream your itunes music from your computer to hifi system with it.
see:
http://silenceisdefeat.com/~rwightman/PVRprojects/Blog/Entries/2010/4/26_Airport_Express_Base_Statio...
see:
Message 16 of 18
(160 Views)
Re: DLink Router
04-05-2010 11:54 AM
hulls,
If you do find that wireless fails altogether on your router we can by all means provide a replacement for you. However it does sound like improving the signal strength is the matter in hand here. As well as bakerbloke's suggestions I'd say it may be worth bearing in mind other similar options too like home plugs may be worth considering.
Message 17 of 18
(160 Views)
Re: DLink Router
04-05-2010 12:16 PM
Thanks all
Homeplugs are great for desktops etc, but are a bit inhibiting for laptops. The cost of the Aerport Express seems similar to buying a new (N) router, but if it's got a better range (?) and is more stable, then I suppose it's worth considering.
Message 18 of 18
(160 Views)
- « Previous
- 1
- 2
- Next »
