DLM reset
loumoodie
DLM reset
My internet has been dropping regularly for the last few months, and I hoping after checking over the wiring and re-terminating the connectors the issue may be resolved.
The line was dropping multiple times an hour and has been stable now for over 2 hours since I reconnected and the attenuation seems to be better.
Can I have a DLM reset on the line as the current speeds are 22down/7u and usually i get near enough 80down.
1 REPLY 1
Marsh
Fixes: 41
Re: DLM reset
Hey @loumoodie,
Thank you for your time on the phone today. As mentioned, I don’t think a DLM reset is necessary at this moment. My tests have found a fault affecting the service, which I believe is causing the disconnection issues. We’ve booked an appointment with Openreach to get this fault repaired.
Josh
