terrible ping for last few days
- terrible ping for last few days
25-01-2025 10:47 PM
I'm down in dorset, everything is very sluggish. Very close to switch hence:
Re: terrible ping for last few days
26-01-2025 7:31 AM
@nurkinator Are you on an FTTC or FTTP connection?
26-01-2025 7:59 AM
Ethernet
Direct WiFi
WiFi extender
DLAN devices
Mesh network
Also what else is using the local network?
26-01-2025 10:34 AM
FTTC.
Ethernet to router
And what I meant was the first hop past the router (which is <1ms)
26-01-2025 12:39 PM
@nurkinator thanks for getting in touch, I'm sorry to hear your ping is so high.
I have done a line test and no faults have been detected, can you check by connecting the broadband cable into the test socket instead for me please. Also, can you confirm which router you are currently using, any Wi-Fi booster, Mesh system, etc.
Look forward to hearing from you soon
26-01-2025 2:13 PM
found out what it was - OneDrive has gone nuts. even though i'm out of storage (5gb) over the last 2 days since i rebooted the router:
Data sent / received:205.4 GB Uploaded / 47.8 GB Downloaded
it was sat there trying to upload a 6gb video.. doh.
absolute piece of chod!
