DLM reset
JHarding
DLM reset
I had a problem with a faulty modem which was was causing multiple disconnections (now replaced) but my line has been capped at 48Mbps.
My connection normally sits at 68-70Mbps could i get a speed profile reset please.
1 REPLY 1
OldBen
Re: DLM reset
Thanks for getting in touch,
if you reply to the private message I have sent to you with your account username I will get a request issued for you. These can take up to 72 hours to be actioned but fingers crossed it'll go through nice and quick.
PNHelp100x100(biglogo).png  Ben
 Plusnet Staff
