DLM reset required after powercut
FIXEDTopic Options
- DLM reset required after powercut
02-10-2024 9:24 PM
Hi
We had a power cut around 10 days ago and my speeds have dropped (FTTC) from a consistent 73/75 meg over lan connected to the router to struggling often to get past 60 meg on a good day. My setup is an open reach fibre modem into a gl.iNet router, so I can’t provide line stats unfortunately. I would really appreciate it if you can do a DLM reset on my line please as I haven’t had such slow speeds in a few years.
Fixed! Go to the fix.
Message 1 of 2
(576 Views)
1 REPLY 1
03-10-2024 3:12 PM
A very helpful advisor has now done this for me and test the line. Thanks
Message 2 of 2
(504 Views)
