DLM Reset
selector14
Re: DLM Reset
Thanks,
I've run the fault bot. It came back and said it appears to be working well.
However my current sync speed to the router is 18mb and under my guarantee speed. Loading seems to be quite sluggish too
Fixes: 382
Re: DLM Reset
What are your current figures, and does your router provide any useful data? It is extremely difficult for any of trying to help, if we are expected o do it blind.
Fixes: 245
Re: DLM Reset
@selector14
What have you done to progress this?
  • You have been advised previously that an engineer is probably required - did you arranged for one to attend (acknowledge a request for a convenient date)?
  • Have you run the faults BOT?  You hint it does not work ... but do not say how it does not work
  • Have you phoned support?
  • You have been asked to supply the router stats on several occasion ... are you obtaining them?
  • Doe you have a PlusNet supplied router you can try out?  That will certainly deliver the required stats...
selector14
Re: DLM Reset
The stats I can see are;
Current rate upload 4457kbps
Current rate download 17997kbps
Max rate upload 4585kbps
Max rate download 52331kbps
SNR margin up 6dB
SNR margin down 10dB
Line attenuation up 37dB
Line attenuation down 17dB
Errors up 2pkts
Errors down 0 pkts
selector14
Re: DLM Reset
I have run the fault bot (as posted previously).
No fault found.
Haven't phoned support as of yet to arrange engineer.
I do have the Plusnet router still in storage
Fixes: 245
Re: DLM Reset
Trying the Plusnet router would be very helpful.
EDIT: Missed the post hidden above the one I linked to from notifications.
Those router stats seem to suggest that the service is indeed (again) banded at 18mbps leading to the elevated SNRM.  The broadband bot can miss issues which the copper circuit test can find ... such magic used to be capable of being run by @Marsh and @Gandalf and @Windings when they roamed these parts.
A DLM reset might be appropriate if a rigorous line test finds no fault (at the time of testing).  One serious disadvantage of a SoGEA service is one cannot plug a telephone into the line and listen for noise.
selector14
Re: DLM Reset
Ok, when I get chance at the weekend I'll swap it over and let you know.
I have posted the stats I can see from my current router above
Fixes: 382
Re: DLM Reset
Looking at the data in post #34 suggests to me there is a fault in the network -  a 10dB d/s noise margin is high, suggesting DLM is trying to manage your connection for stability.
selector14
Re: DLM Reset
Thanks jab1,
So is it best to contact support on this?
Fixes: 245
Re: DLM Reset
Yes, see my edit.
Fixes: 382
Re: DLM Reset
Let us see what the PN Hub tells us - it is somewhat more informative.
@Townman Sorry - cross-posted before I saw your edit.
Fixes: 245
Re: DLM Reset
@jab1
I do not think that the PN Hub will be any more helpful.  Given the lack of response to the question before, I was starting to believe that the user's router provided nothing useful ... it absolutely does ... if this had been provided earlier, better advice could have been offered weeks ago.
Fixes: 382
Re: DLM Reset
@Townman  - OK. 😀
selector14
Re: DLM Reset
My apologies on the delays. I wasn't aware what my router showed and have just been incredibly busy
Fixes: 245
Re: DLM Reset
Yes, but you've been searching for answers... and guidance.
