DLM Reset
Anywho
DLM Reset
Can I request a DLM reset on my ADSL please?
I understand you are very busy right now - so whenever you get the chance will be fine.
3 REPLIES 3
Fixes: 1,660
Re: DLM Reset
I've done the DLM reset for you now.
Let me know if there's anything else you'd need help with
Anywho
Re: DLM Reset
Thanks!
I noticed it reset in the afternoon but the first reconnect just came back at the same "speed"... later it reconnected again and came back at line max... so I'll just give it a couple of weeks to do its thing/settle and then I'll make my adjustments.
Just one question... Does a DLM reset change the stability profile back to default (I was on normal I think I would prefer aggressive)? I guess I'll see in time anyway!
Thanks again.
Fixes: 1,660
Re: DLM Reset
Glad to see that! A DLM reset doesn't alter the stability profile.
