DLM Reset
- Re: DLM Reset
DLM Reset
15-02-2025 1:26 AM
Had a period of instability which has been fixed and has been stable for over 2 months now. Would appreciate a DLM reset to return to previous speeds, thanks!
Message 1 of 3
(608 Views)
2 REPLIES 2
Re: DLM Reset
15-02-2025 4:34 PM
Hi @Welpz,
Do you wanna send me your plusnet username in a private message and I will have a look into getting that done.
I sent you one so you can just reply to it.
Thanks,
Lex
Message 2 of 3
(551 Views)
Re: DLM Reset
16-02-2025 3:36 PM
Message 3 of 3
(521 Views)
