Customer service number
Samantha4185
My internet is down but all contact numbers for plusnet are saying closed even though it’s supposed to be open 8-8.
5 REPLIES 5
Fixes: 383
Re: Customer service number
0800 432 0200 is definitely open.
Samantha4185
It lets me pick options then says sorry this line is closed and ends call
Fixes: 383
As I'm no longer a PN customer, I don't want to get too deep into the system.
If you have a fault, the quickest way to resolve it is via: https://www.plus.net/help/report-a-problem/broadband/
Longliner
All Star
Fixes: 8
@Samantha4185  Follow John's advice and if you still can't get it sorted, people here will try to help if you post some info. Are there lights on your router and what colour? There is basic troubleshooting info in your Plusnet booklet.
Mike
willcutforth
Fixes: 113
Hey there @Samantha4185 I can see you spoke to someone yesterday to get it sorted. Do you need anything else?
 Will Cutforth
