Could the Plusnet Line Speed Be Put Up?
- Re: Could the Plusnet Line Speed Be Put Up?
13-02-2012 12:19 PM
The IP profile updated to 5.5Mb last night, is it possible for the Plusnet line speed to be changed to match this?
Thank you.
13-02-2012 3:30 PM
Just checked and your BT IP profile is currently 350k so not sure what's going on there!
Jojo
13-02-2012 3:47 PM
Download speedachieved during the test was - 1.33 Mbps
For your connection, the acceptable range of speeds is 600 Kbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :6.37 Mbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5.5 Mbps
13-02-2012 3:52 PM
13-02-2012 3:52 PM
13-02-2012 5:02 PM
Also, have the PN scripts that update the PN Current Line speed been running as normal the last few days? I've encountered a couple of anomalies - (all OK now). Is it possible that the inconsistencies are related to the work that took place on the Speedtester update?
13-02-2012 5:11 PM
13-02-2012 5:19 PM
16-02-2012 8:22 AM
The BT IP profile has now increased to 6.5Mb, could this be changed on Plusnet's side?
Here is a BT speed test:
Download speedachieved during the test was - 5.04 Mbps
Your DSL Connection Rate :7.52 Mbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6.5 Mbps
16-02-2012 10:20 AM
16-02-2012 11:16 AM
16-02-2012 11:34 AM
(It's a problem which BT and PN are currently trying to resolve.)
16-02-2012 1:19 PM
