Could my speed be checked please
Fixes: 416
Re: Could my speed be checked please
As you say it looks like 21CN is available after all Smiley
I'm sure one of the Digital Care team will pick this up tomorrow ( they don't work weekends ) and sort out getting you upgraded to ADSL2+.
elkieluca
Hope they see it , thanks again misterW.
jojopillo
Hi elkieluca,
I've placed the order manually to put your line onto ADSL2+. This takes 5 working days to complete, so should be done next Monday.
Jojo Smiley
elkieluca
Thank you Jojo.  Can you tell me will I have to do anything to my router as I'm not sure I understand how it works to be honest.
jojopillo
No, you won't have to do anything. On the day, you'll notice a short service break while they move your line to the new equipment and that's about it! Smiley
elkieluca
Thank you very  much.
elkieluca
Hi Joanne,
My broadband should  have been changed to get a higher download speed today but I have checked it a few times and its the same as always. Could you check please.
jelv
Fixes: 10
Do you mean you are getting the same speed on speed tests or when you run a BT speedtest it is still testing the download only?
If it tests both download and upload post what it says for the download IP Profile and no doubt JoJo will press the magic button tomorrow.
Edit: Explanation on 20CN it tests download only - on 21CN (ADSL2+) both.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jojopillo
Hi elkieluca,
I have raised your profile to 11900 to allow for your new BT IP profile. This should take effect shortly.
Jojo Smiley
elkieluca
Thank you Joanne,
Its great I'm getting 11.21 down and 1.08 up  Smiley
jojopillo
Great, thanks for letting me know Smiley
