Constant drops
Darren8282
Re: Constant drops
Yeah mate. Baffled now altogether tbh.
Darren8282
Re: Constant drops
Just to update thread it's went off 6 times this morning. Done quiet line test also, router went straight off and lots of noise, crackling on line. 👍
Fixes: 382
Re: Constant drops
Report a phone fault.
SammyM
Fixes: 101
Re: Constant drops
Hiya @Darren8282
I'm really sorry for the issues you are facing with your connection and for the hassle this is causing. I can imagine it the frustrations this is causing.
We're a little busier than usual and it is taking longer than I would like to get back to you guys, sorry about that.
I have checked the fault and an engineer is attending to this externally today and the connection will be more intermittent than usual while this work is ongoing.
Our faults team will review the engineer notes tomorrow and will update you cia the fault ticket.
 Sammy M - Sheffield Team
Darren8282
Re: Constant drops
