Constant Disconnection / Reconnection
- Constant Disconnection / Reconnection
29-07-2022 11:25 AM
Me again
Continuing from the previous thread
After the banding was removed, Internet was fine for weeks, high speeds no drops etc. but recently after coming back from a week away there's a new problem
Basically the internet connection is constantly disconnecting and then reconnecting moments later at a completely different speed, anywhere between 10Mbps and 500Kbps, the disconnects happen sometimes 10+ times before stopping and staying on a specific speed that's anywhere between the above speed, and stay that way for about a day, during these errors the router itself is not flashing orange or seemingly being reset
Manually resetting the router does nothing
Doing the automated line checker service tells me there is no fault
Quiet line test is silent
All the usual testing procedures Plusnet recommends does nothing
Here are the router stats between 2 random disconnect / reconnects, moments apart
| 6. Data rate: | 910 / 9125 |
| 7. Maximum data rate: | 18442 / 9136 |
| 8. Noise margin: | 7.7 / 6.1 |
| 9. Line attenuation: | 21.1 / 41.3 |
| 10. Signal attenuation: | 21.1 / 39.5 |
| 6. Data rate: | 882 / 2539 |
| 7. Maximum data rate: | 17716 / 9352 |
| 8. Noise margin: | 3.9 / 22.5 |
| 9. Line attenuation: | 21.0 / 41.0 |
| 10. Signal attenuation: | 21.0 / 39.9 |
Re: Constant Disconnection / Reconnection
29-07-2022 12:04 PM
Accidental repost, ignore / delete
