Connection rate / Ip profile low
- Connection rate / Ip profile low
13-10-2010 1:46 PM
For the last week my connection speed has dropped through the floor and my download speeds are a fraction of what they where. Tried to download a 700mb file last night but at only 25kb/sec it would have taken 10 hours, previously it would have taken 20 mins ha ha. I cannot even play Starcraft 2 anymore, when there is lots going on it lags up to much.
My connection has never been great, my line attenuation averages at 6-7db, which is god awful (I have been looking at rigging up a duel WAN router with my mobile phone just so I don't drop out of games at bad times), not so surprisingly it does drop the connection every now and then, but when it is connected it has always been pretty speedy. Fast enough to play games with no lag and view web pages at the same time or download files at a fair rate of about 700kb/sec.
Well anyway I have read other posts and have an idea of what you guys migh ask for. I have collected some readings over the last 3 days.
speed test results
11/10/10
http://www.speedtester.bt.com
11/10/10 - 19.25
Download speedachieved during the test was - 183 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :320 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 250 Kbps
11/10/10 - 19.30
Telephone number:
01243######
Phone exchange:
MIDDLETON ON SEA
Estimated line speed:
5 - Checked on 2010-06-07 16:52:40
Current line speed:
6500
router connection stats
11/10/10 - 19.35
downstream upstream
Connection Speed 320 kbps 448
Line Attenuation 41 db 15.5
Line Attenuation 12 db 6
http://www.btwholesale.com/includes/adsl/main.html
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
speed test results
12/10/10
12/10/10 - 22.51
Download speedachieved during the test was - 299 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Your DSL Connection Rate :0 Kbps(DOWN-STREAM), 0 Kbps(UP-STREAM)
IP Profile for your line is - 350 Kbps
12/10/10 - 22.55
Telephone number:
01243######
Phone exchange:
MIDDLETON ON SEA
Current line speed:
250
12/10/10 - 22.55
downstream upstream
Connection Speed 512 kbps 448
Line Attenuation 42 db 15.5
Line Attenuation 6 db 6
speed test results
13/10/10
13/10/10 - 12.52
Download speedachieved during the test was - 181 Kbps
Your DSL Connection Rate :608 Kbps(DOWN-STREAM), 256 Kbps(UP-STREAM)
13/10/10 - 12.52
Telephone number:
01243######
Phone exchange:
MIDDLETON ON SEA
Current line speed:
250
13/10/10 - 12.52
downstream upstream
Connection Speed 608 kbps 256
Line Attenuation 50 db 15.5
I hope you guys can shed some light on this annoying dilema. It is like being in the 90s again with the slow ass speed, oh but without that terrible band Ace of base, which is lucky, that would be the nail in the coffin =p
Re: Connection rate / Ip profile low
13-10-2010 3:37 PM
It looks like there might be a fault with the local loop, so the first thing you need to do is raise a fault so we can escalate this further for you. You can do this at http://faults.plus.net
Jojo
13-10-2010 4:44 PM
13-10-2010 4:48 PM
Nice one, I'll keep an eye on things and see how it goes. It can be 48-72 hours for an update though.
Jojo
15-10-2010 4:51 PM
Download rates are still very low but I guess that's becuase my IP Profile or whatever it is still thinks the line is duff.
Here are the test results for today
Download speedachieved during the test was - 206 Kbps
Your DSL Connection Rate :6624 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Telephone number:
01243######
Phone exchange:
MIDDLETON ON SEA
Current line speed:
350
downstream upstream
Connection Speed 6624 kbps 448
Line Attenuation 30 db 8
Line Attenuation 12 db 25
Notice my router has a connection speed much higher now. I shall give it a few days and hopefully the machine on your end will bump up my connection.
15-10-2010 5:26 PM
I've just ran a line test and the Ip profile has not lifted yet. I will check later for you though and lift it at our end if necessary. Watch this space!
Jojo
15-10-2010 9:58 PM
Still 250 I'm afraid, I'll check again for you tomorrow.
Jojo
18-10-2010 3:56 PM
Telephone number:
01243######
Phone exchange:
MIDDLETON ON SEA
Current line speed:
250
Download speedachieved during the test was - 180 Kbps
IP Profile for your line is - 5500 Kbps
But my ip profile is back to around what it should be.
18-10-2010 4:52 PM
I've just matched our profile to the 5500 so if you disconnect/reconnect in the router you'll see the increase.
Jojo
20-10-2010 3:21 PM
20-10-2010 3:32 PM
Jojo
