Connection problems
- Re: Connection problems
Connection problems
11-04-2008 11:33 AM
I have just developed a problem which sounds identical to a member whose message I came across when looking for ideas in an attempt to solve it:
"I used to be able to connect to the server from Outlook by pressing Send/Receive - now this no longer works and I get the following error message (or variations on it: there've been 2 or 3 variations on the error number):
Task 'mail.plus.net - Receiving' reported error (0x80042108) : 'Outlook is unable to connect to your incoming (POP3) e-mail server. If you continue to receive this message, contact your server administrator or Internet service provider (ISP).'"
The result being I cannot send or receive mail. I have tried the solution which appears to have worked for this member, i.e. change setting to "connect using phone line" but without success. I can connect to the internet without any problems. I use Outlook Express. Any suggestions?
11-04-2008 11:37 AM
Can you confirm that the server name that you are using is "mail.plus.net" ?
Are you able to connect to the internet and browse webpages when you are getting the same problem?
11-04-2008 11:47 AM
yes, I'm using mail.plus.net
I have been able to continue browsing web pages without any issues
11-04-2008 11:48 AM
Can you tell me what happens when you open a command prompt and type:
telnet mail.plus.net 110
11-04-2008 11:55 AM
11-04-2008 11:57 AM
Click on your start menu
Click on run
Type cmd, hit enter
Then type the command I wrote down in my earlier post. (and hit enter)
11-04-2008 12:02 PM
I got: "could not open connection to the host, on port 110: Connect failed"
11-04-2008 12:03 PM
Could you possibly try disabling your antivirus and/or firewall software and trying the same command again?
11-04-2008 12:10 PM
11-04-2008 12:50 PM
Hope that helps,
11-04-2008 2:29 PM
