Connection keeps dropping - what to do next?
- Re: Connection keeps dropping - what to do next?
08-05-2012 5:24 PM
However, past month connection has started dropping regularly, quite a few times a day. Speeds are not dropping though, which I'm grateful for - I'd rather have a fast connection when I've got it! I've sat on the problem for a while as I'd had a belly full of sorting the last problem, but now it is starting to get annoying. Sometimes I have to disconnect and reconnect manually through logging on to the router, sometimes that doesn't work and I have to unplug router briefly.
The router is only about 3 months old (Thomson TG585 v8 software 8.2.7.8), but I do have my old Netgear around which I could try to see if it's the router's fault.
I had a ferret about and found these stats in the router below - could someone take a look and see if they can see a problem and even better a solution? I also took a screen grab of event logging which I'll try to attach, maybe that will help too.
Thanks all!
DSL Connection
Link Information
Uptime:
0 days, 0:09:08
DSL Type:
G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]:
944 / 9,760
444 / 7,512
Data Transferred (Sent/Received) [kB/MB]:
517.00 / 2.73
Output Power (Up/Down) [dBm]:
12.5 / 20.0
Line Attenuation (Up/Down) [dB]:
22.0 / 37.5
SN Margin (Up/Down) [dB]:
20.5 / 10.5
Vendor ID (Local/Remote):
TMMB / IFTN
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
262,143 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
Error Seconds (Local/Remote):
393,222 / 0
FEC Errors (Up/Down):
0 / 96,406
CRC Errors (Up/Down):
207 / 574
HEC Errors (Up/Down):
243 / 14,573
08-05-2012 5:33 PM
You could try swapping out any ADSL filters you have (and of course making sure you've remembered to fit them to ALL phones, faxes, alarms, ringers, Tivos, etc...)
08-05-2012 5:34 PM
08-05-2012 5:34 PM
08-05-2012 5:39 PM
08-05-2012 5:50 PM
When you say "Sometimes I have to disconnect and reconnect manually through logging on to the router", do you mean you click on the "Disconnect" button in the Internet box, and then click on it again when it's saying "Connect"
If so, this is only dropping your "ppp" session to Plusnet and not affecting your line sync to the exchange. I'd suggest you do the following now -
Login to the modem/router interface and click on the "Disconnect" button - this terminates the "ppp" session to the ISP (not sync to the exchange) as mentioned. Wait a good minute after the button changes to "Connect" (refresh the page to be sure).
Then power down the modem/router. Wait a good minute before unplugging the modem/router or it's filter from the line. Then swap the filter if you have a spare, then wait 10 minutes before you power up again.
4 reasons for this suggestion, the Local(upstream) Error Seconds are enormous for the short uptime, this could suggest a faulty filter. Powering down the modem/router will reset all the statistics, so we have a clean start, and the procedure helps the exchange DLM to not think you have a worse dropping connection than you have, which might result in Banding or a raised Target SNRM (Noise Margin) which would result in a slower speed. 4th reason I've sent a PM about.
Post some more stats as soon as you are on line and then some say after an hour.
Edit: Always follow that procedure when you want to swap things about.
08-05-2012 7:03 PM
'When you say "Sometimes I have to disconnect and reconnect manually through logging on to the router", do you mean you click on the "Disconnect" button in the Internet box, and then click on it again when it's saying "Connect"'
Yes, that is what I mean.
However, I have now followed your advice to disconnect completely, have switched in another filter (although the old one came as new with the new router 3 months ago). I've screen grabbed three lots of new stats as not sure which ones you want but seem unable to post them, what am I doing wrong? I go to additional options and attachments, browse to the files and select them, press post but nothing happens (I'm on a mac by the way). If someone tells me where I'm going wrong I'll upload them.
Anotherone: I have followed your advice re pm you sent me (I hope).
Thanks all for input!
08-05-2012 7:12 PM
08-05-2012 7:31 PM
08-05-2012 7:44 PM
Can you hear any crackling or other noises on your phone line when using the phone?
08-05-2012 9:36 PM
I hope it's not the return of the dreaded HR line fault! That drove me nuts...
08-05-2012 9:52 PM
Who do you pay line rental to?
Next time the noise is present, do the disconnect procedure for your modem/router and then plug a known good corded phone direct into the test socket and confirm the noise is present. Phone and report it whilst the noise is present and try and do so before there is an incoming call - ringing current can sometimes "clean" a bad connection and the noise disappears for a period. Tell the Call taker that you are plugged into the test socket with a known good corded phone. Don't mention the broadband otherwise you may get given the run around. Get the call taker to confirm they can hear the noise, request them to log that fact and the fact that is intermittent. Request that that detail is passed to the Openreach engineer. These requests are important to make sure you don't get a No fault found bill if an engineer can't find a fault, but if the engineer is aware it's intermittent they should know a few things to check if they are any good.
08-05-2012 10:00 PM
08-05-2012 10:04 PM
10-05-2012 6:15 PM
Here are stats
Uptime: 1 day, 23:15:46
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,152 / 11,224
Bandwidth (Up/Down) [kbps/kbps]: 444 / 8,301
Data Transferred (Sent/Received) [MB/GB]: 107.72 / 1.61
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 21.5 / 37.0
SN Margin (Up/Down) [dB]: 27.0 / 12.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,539 / 0
FEC Errors (Up/Down): 0 / 68,879
CRC Errors (Up/Down): 44 / 277
HEC Errors (Up/Down): 13 / 7,396
Maybe I just needed to do a reboot?
Thanks for your help by the way!
