Connection dropping multiple times every day.
- Connection dropping multiple times every day.
23-09-2021 9:25 PM
I've heard that the plusnet router is infamous for this kind of issue so should I get a new router maybe?
Re: Connection dropping multiple times every day.
23-09-2021 9:49 PM
Is it the connection to broadband that drops, or the connection to WiFi?
If broadband, then keep up the fault reports to PN.
If WiFi a BT HH6 from the well known auction site can be a cheap fix, but there are plenty of decent modem/routers available depending on your budget and requirements.
24-09-2021 10:04 AM
Frustrating.
24-09-2021 10:17 AM - edited 24-09-2021 10:21 AM
Hiya @Keeden501, thanks for getting in touch. I am sorry for the issues with your service and for the inconvenience caused.
I can see there were a high number of drops occur yesterday evening (see image below) but our testing hasn't highlighted what may have caused this.
I would advise to have a run through our troubleshooting here: https://www.plus.net/help/broadband/connection-troubleshooting/ and connect to the test socket for the time being as shown here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242 to rule out any internal causes.
Should this not the resolve the issue, we will need to look at sending an engineer. If you update the ticket here: https://www.plus.net/wizard/?p=view_question&id=217874550 we can get that progressed for you.
