Congestion!!!!!!
- Congestion!!!!!!
- « Previous
- 1
- 2
- Next »
Re: Congestion!!!!!!
04-05-2011 6:07 PM
05-05-2011 9:06 AM
It has done previously so I'll give them the go-ahead and let you know what they say.
Jojo
05-05-2011 6:03 PM
06-05-2011 7:57 AM
Just had an email back to say that the order's been placed to move you to another VP and it's expected to be complete by the end of today.
Jojo
06-05-2011 2:09 PM
06-05-2011 2:49 PM
I'm not 100% sure if it's happened yet until I get confirmation but from the BT system I am still seeing an IP profile of 6000.
Jojo
06-05-2011 3:56 PM
Your DSL Connection Rate :7808 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps#
Never had an Profile issue in the past, i just thought that this may have been a sideffect from the possibility of the VP already having been changed...
06-05-2011 4:47 PM
Looks like it has been changed now. The default setting is 2000 so that's why you're seeing that but it should be on 6500 now so I'm going to have to get onto BT now to try to amend that. I'll let you know what the outcome is.
Jojo
06-05-2011 5:32 PM
That should be back to 6500 now but if you don't see that wait a while and reboot your router via the router homepage.
Jojo
06-05-2011 11:57 PM
08-05-2011 12:09 PM
08-05-2011 6:49 PM
always max speed possible at peak time :)! Better then the 500-1.5meg i was getting.
Estimated line speed:
8Mb (Accurate to within +/- 1Mbit) - Checked on 2011-02-28 09:09:54
Current line speed:
6 Mb
Your DSL Connection Rate :8000 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Just limited by the Profile on plus net portal now it needs updating.
08-05-2011 7:15 PM
- « Previous
- 1
- 2
- Next »
