I am really cheesed of with the IP profile system
Oldjim
Resting Legend
Fixes: 63
My line went bad yesterday evening with a very high error rate so I tried a router resync with no effect then a router reboot. This last one dropped my sync rate to just under the 4000kbps IP profile level so I immediately (within 1 minute) did another resync using DMT with the noise margin forced down a bit. Result 4544kbps sync speed. The errors still kept increasing until about 11pm whwn every thing went back to normal. - error rates shown on the graph from Routerstats.
In that one minute blip the BT automatic system dropped my IP profile down to 3,500kbps - that isn't what the BT speedtest gave as it is still giving silly results but that was the effect on speed.
34 REPLIES 34
ReedRichards
Seasoned Pro
Fixes: 25
Re: I am really cheesed of with the IP profile system
But there's no solution other than changing to an ISP that doesn't use the IP profile system - if you actually have that option (I don't).
Oldjim
Resting Legend
Fixes: 63
Oh yes - TalkTalk or Sky  Sad or Tesco  Crazy from the end of May according to SamKnows - better the devil you know
paulh
For the past couple of days (and currently), Jim , 3500 would be a luxury; I'm stuck on sub-1M on a line that normally runs at 6.5M ... so I'm also feeling very unimpressed indeed at the moment
billnotben
I think just about everyone and his dog is fed up with the IP profile system. It seems like I'm waiting for Christmas stuck on a banded 2000 profile. Only the drm gremlin and Elvis knows why. Angry
Oldjim
Resting Legend
Fixes: 63
Now something is messing with my upstream speed.
for no obvious reason my line resyched with an upstream speed of 160kbps - a resync brought it back up to 448kbps although the noise margin is a bit low
and it just went down again
Oldjim
Resting Legend
Fixes: 63
Now this is interesting - IP profile has recovered and the Plusnet version matches it at 4000kbps but this is the result of the speed test
pierre_pierre
Hope your not complaining Jim, I will have to report you to the thought police Roll_eyes Tongue Smiley
billnotben
Recently I don't believe either the speed at the Plusnet end or the BT result. For some unfathomable reason I'm on a banded profile. Plusnet say 2meg, BT say 1750, my router says 3072. But for the last couple of days it's been downloading at 3meg speed.
The only thing that matches is the screwyness at both the BT and Plusnet ends.
I'm not complaining about the speed, 3meg works for me, but it would be nice if the collars and cuffs matched.
jojopillo
HI Jim,
What results are you getting on other speedtesters?
Jojo Smiley
Oldjim
Resting Legend
Fixes: 63
Not relevant as my line just picked up a load of interference which wiped out all the higher frequencies.
Noise margin dropped from 6 to 0.3 and lost connection.
Reduced speed from 4800 to 3900 with 6dB noise margin.
After about 40 minutes the noise margin increased to 10.5dB
I blame the builders equipment next door - directly under the telephone wire to my house
Will leave it alone for 24 hours and see if it happens again
jojopillo
Hi Jim,
I'm looking into this with Dave so it would help to know what you got with other speed tests.
Jojo Smiley
Oldjim
Resting Legend
Fixes: 63
I didn't do any as that would mean disabling Kaspersky
Oldjim
Resting Legend
Fixes: 63
just for Dave I have run some tests - note that the Plusnet profile is still at 4000kbps as it hasn't picked up the drop
jojopillo
Thanks Jim Smiley
