Configured Download Throughput Speed is 6500K
- Re: Configured Download Throughput Speed is 6500K
- « Previous
- 1
- 2
- Next »
13-02-2009 12:06 PM
03-03-2009 9:34 AM
However I'm seeing an increased number of 'Uncorrected Blocks' on my router. This never used to leave zero and I've had 750 in the last 90mins, is this something I should be worried about?
[tt]--------------------------- ATU-R Info (annex A) ----------------------------
Running Mode : ADSL2+ State : SHOWTIME
DS Actual Rate : 18810700 bps US Actual Rate : 1071800 bps
DS maximum Rate : 18810700 bps US maximum Rate : 1071800 bps
DS Path Mode : Interleave US Path Mode : Interleave
NE Current Attenuation : 18.5 dB Cur SNR Margin : 3.0 dB
DS actual PSDM(C) : 00000000 US actual PSDM(R) : 00000000
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 11.5 dB Far SNR Margin : 14.0 dB
CO ITU Version[0] : 00000000 CO ITU Version[1] : 00000000
DSLAM CHIPSET VENDOR : < Unknown >
INTL, DSTREAM bytes/depth= 0, symbols/codewords = 0, latency= 0*0.25ms.
, USTREAM bytes/depth= 0, symbols/codewords = 0, latency= 0*0.25ms.
CODE, DSTREAM fast parity bytes= 0, fast codeword= 0.
DSTREAM intl parity bytes= 0, intl codeword= 0.
CODE, USTREAM fast parity bytes= 0, fast codeword= 0.
USTREAM intl parity bytes= 0, intl codeword= 0.
Setting>>
FDQ : Enable, TCM : Enable, EC : Disable, Framing Mode : 3.
Running>>
FDQ : Off, TCM : Off, EC : Off.
DS : Framing Mode 3, US : Framing Mode 3.[/tt]
03-03-2009 10:06 AM
Test1 comprises of Best Effort Test:
-provides background information.
Your DSL connection rate: 18810 kbps(DOWN-STREAM), 1071 kbps(UP-STREAM)
IP profile for your line is - 13000 kbps
Actual IP throughput achieved during the test was - 1641 kbps
03-03-2009 10:15 AM
The number of uncorrected block has gone up, because there's no interleaving to correct them.
What results do you get from say, the thinkbroadband speed tester?
Our seems to be giving some fairly spurious results recently.
03-03-2009 10:16 AM
03-03-2009 11:12 AM
[tt]Speed Test Results
Date 03/03/09 11:09:07
Speed Down 1780.85 Kbps ( 1.7 Mbps )
Speed Up 817.62 Kbps ( 0.8 Mbps )
Port 8095
Server speedtest1.thinkbroadband.com[/tt]
According to their tests my connection is slightly slower than DSL 2 Meg.
03-03-2009 11:15 AM
03-03-2009 12:33 PM
thinkbroadband is now showing...
Date 03/03/09 12:29:43
Speed Down 10419.94 Kbps ( 10.2 Mbps )
Speed Up 817.53 Kbps ( 0.8 Mbps )
Port 8095
04-03-2009 11:16 AM
Are fluctuations like this normal? I never experienced such problems before moving over to the 21CN.
04-03-2009 1:48 PM
31-07-2009 9:16 AM
However in the past few weeks I've noticed a marked drop in my connection speed.
I was experiencing speeds of 18Mbps (see Reply #16 on 03/03/2009, 09:34) but this has nearly halved and I'm now running at 10Mbps. Nothing has changed my end so something has happened at the exchange or beyond.
Has anyone else seen this sort of behaviour and is there anything I can do to return the link to what it was?
DS Actual Rate : 10529600 bps US Actual Rate : 1087900 bps
DS maximum Rate : 10529600 bps US maximum Rate : 1087900 bps
NE Current Attenuation : 19.0 dB Cur SNR Margin : 14.0 dB
Far Current Attenuation : 12.0 dB Far SNR Margin : 14.0 dB
Setting>>
Running>>
31-07-2009 9:26 AM
Quote from: pnf Two days ago my IP Profile was 12,000 kbps, it is currently 11,000 kbps and two weeks ago it was 10,000 kbps. This seems to be the norm for me at least. ADSL2+ is more volatile than ADSL1, when I was on ADSL1 I never had any disconnects and my downstream sync speed was always 8096 kbps.
Do you notice these sync changes or does the line become sluggish at times? ADSL2+ has a feature called Seamless Rate Adaption, SRA would stop those problems, but BT have not enabled it, preferring to homebrew their DLM software/logic!
SW.
3Mb FTTC
- « Previous
- 1
- 2
- Next »
