Changing my I.P Address
- Changing my I.P Address
15-07-2011 10:02 AM
Hi guys!
A friend of mine while visiting, used his laptop on a website that I frequent and got himself banned, therefore, my IP has been banned.
Is there anyway of having my IP address changed permanently to something else?
Message 1 of 4
(1,048 Views)
3 REPLIES 3
Re: Changing my I.P Address
15-07-2011 12:53 PM
Some friend!
Most Plusnet customers do not have a fixed IP address so you can change it by restarting your router (or disconnecting from the session and reconnecting).
Message 2 of 4
(496 Views)
16-07-2011 10:32 PM
Or try using "The Onion Router" https://www.torproject.org/
Providing you (your username) has not been banned you should still be able to login and ask the admin's to remove the IP ban.
Message 3 of 4
(496 Views)
18-07-2011 4:46 PM
Probably better to drop one of the admins an email though and let them know what happened rather than doing so via a proxy (unless you need to use the proxy to send the message that is) as it can look dodgy the other way.
Message 4 of 4
(496 Views)
