Changing Modem?
- Re: Changing Modem?
Changing Modem?
23-02-2010 6:39 PM
Changing Modem???
Is there any special procedure to changing a modem over?
Or is it just switch of leave for 5mins Remove, Replace and switch the new one back on.
Andy
Andy
Message 1 of 4
(792 Views)
3 REPLIES 3
Re: Changing Modem?
23-02-2010 7:07 PM
You don't even have to leave for 5 minutes if you don't want to.
As a thought you could connect your computer to it while it isn't connected to the telephone line and put all your login settings in.
Message 2 of 4
(378 Views)
Re: Changing Modem?
23-02-2010 7:11 PM
Do you really mean a modem or do you actually mean a router?
If it is a modem and you are replacing with a router there may be more things you need to do. If it's just a straight router swap then as long as the default IP range is the same then it should not be a difficult swap - you will need to configure the new router with your ADSL connection details, unless it has been supplied by PlusNet (a 585V7 or 585v8) in which case it will auto-confirure after power on.
Message 3 of 4
(378 Views)
Re: Changing Modem?
24-02-2010 1:47 AM
Hi All
Thanks for the replys Nice mr plusnet sent me a brand new one but i have managed to get hold of a brand new Netgear DG834GT only negative is its a sky one But i only paid a tenner for it Which i dont think is bad I have d/l netgear tools and the latest firmware which i am told works fine. So as soom as it comes i will be away. and setting it up. It was the removing the line and the resyncing i was thinking about As for the router i will just set it up offline liike OldJim suggested with my lan settings and name as well as the F9 log on settings.
Regs Andy
Regs Andy
Message 4 of 4
(378 Views)
