Changed product now slower speeds
- Re: Changed product now slower speeds
23-11-2009 11:20 AM
I wonder if anyone can help regarding a few issues I have.
1. I transferred house & now my speeds have dropped around 2mb which I'm guessing is due to me being further away from the exchange, not a problem but today I transferred to PlusNet's Premium from PlusNet Broadband Your Way Option 2 and speeds have dropped further 2mb, I now get an average of 1852kbps, anyone care to share some light on this as I thought WBC MAX24 mb/s (ADSL2+ Annex A) would have been the same speed or best still improved ?
2. Whilst changing products with PlusNet I also ordered a FREE wireless router and paid the P+P of £6.99, will this help with ADSL2+ as my old router is an old Belkin which must be at least 5 yrs old now, I'm guessing the connection is unable to use ADSL2+ and still uses the old ADSL format due to hardware restrictions ?
3. When am I likely to receive my router from PlusNet as I transferred over today and have had not confirmation regarding when I will receive this router only confirmation that my deferred hardware - Wireless 4 port router contract has now started.
Thanks in advance for any help.
Regards
23-11-2009 11:51 AM
What does http://www.speedtester.bt.com/ say for your IP profile? (Posting the full output from the test would help)
23-11-2009 12:30 PM
Yes current line speed is 2000
Estimated line speed:
4.0 - Checked on 2009-11-14 15:38:07
Current line speed:
2000
My BT IP test a few days ago before product change was:-
Download speed achieved during the test was - 3050 Kbps
Additional Information:
Your DSL Connection Rate :4672 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 4000 Kbps
Unfortunately I am unable to test again atm as did a test an hour ago and failed to save those details and therefore have to wait the 3 hours BT request.
"You have attempted a repeat test within 3 hours of the test providing results on your circuit. Please allow a minimum of 3 hours between tests."
Thanks once again for your reply Jelv.
Regards.
23-11-2009 1:02 PM
You need to ring in to ask for your stable rate to be set to match your IP Profile - don't be fobbed off if you are told to raise a fault - ask to speak to someone else
If you don't succeed hopefully one of the comms team will pick up this post.
23-11-2009 1:41 PM
Thanks for your help jelv, I can also ask them where my new router is
Thanks once again.
Regards
23-11-2009 1:59 PM
I've changed your profile on our side to match BTs (4000kb/s) - should take effect instantly, though reconnect if you've not noticed anything.
Hope that helps,
23-11-2009 10:27 PM
Hi orbrey,
Your a star!
Thank you very much, it's back to normal now, I noticed the increased speed earlier even though I was told over the phone I would have to wait 3 days, glad you helped me out.... very much appreciated orbrey.
Regards.
23-11-2009 10:48 PM
(Incidentally Matt picked up this topic when he did because I PM'd him and asked him to sort it for you)
24-11-2009 11:20 AM
Quote from: jelv Hang on! Were you told that it would take up to 3 days when you rang in after reading my post?
Yes, I did think about your post but in the back of my mind having just been told over the phone my new router had not been sent out as it was a problem on PlusNet's system and I should receive it within 3 days I thought maybe the best thing to do was to wait until the new router arrived and then call them back if no change, I guess I was a little apprehensive in my demand as the customer advisor was very polite lol, I'm a sucker for manners.
Quote from: jelv
I thought he may have just stumbled upon my post but now I know you PM'ed him....... you get a double thanks!
That double thanks was not intended to be insincere either, the fact I'm back to the speed I was at before my product change means I have resolved my main issue that I created this topic for, jelv you've been a great help........ and I mean that.
Thanks once again.
Regards.
24-11-2009 11:54 AM
Please could you ask Mand to get the educating tool out and ask her to speak to CSC about how to deal with current line speed not matching IP Profile:
"Do you know how long it has been since your IP Profile has been at that speed"
Less than 12 hours: "It should correct itself within 12 hours, if it hasn't please contact us again"
More than 12 hours: "Just wait a minute please... If you'd like to disconnect/reconnect you should find your speeds have improved"
25-11-2009 3:51 PM
Matt's off for a few days, but I'm more than happy to go and 'educate' whichever agent it was myself.
25-11-2009 4:46 PM
25-11-2009 4:53 PM
