Changed my deal and speed falls
- Changed my deal and speed falls
Re: Changed my deal and speed falls
19-01-2010 4:16 PM
I dont know how to forward my routerstats light graph thpough I can capture it , even though I can e mail it I dont seem to be able to copy and paste it as it seem to be saved to picasso
19-01-2010 4:19 PM
19-01-2010 5:57 PM
19-01-2010 7:31 PM
Management and Diagnostic Console
System Summary
Broadband Link
• Summary
• Statistics
• Detailed Statistics
• Configure
Local Network
• Status
• Statistics
• Device List
• Wireless
• Configure
• Address Allocation
Firewall
• Settings
• Detailed Information
• Advanced Settings
Troubleshooting
• DSL Diagnostics
• Event Log
• Network Tests
• Upgrade History
• Resets
Advanced
• Syslog Settings
• Provisioning Info
• Configure Time Services
• Configure Services
• Static Routes
• DNS Resolve
• Traffic Shaping
• Link Manager
• Detailed Log
Troubleshooting – DSL Diagnostics
General Information
DSLAM: Country: {0x0F} Vendor: {ALCB} Specific: {0x00}
DSL Line (Wire Pair): Line 1 (inner pair)
Downstream Rate Cap: 8128 kbps
Downstream Atten. at 300kHz: 68.4 dB
Uncancelled Echo: -14.1 dB Ok
VCXO Frequency Offset: 24.2 ppm Ok
Final Rx Gain: 34.5 dB Ok
Impulse Noise Comp. Tones: 0 Ok
Excessive Impulse Noise: 0 Ok
Impulse noise protection: 0.00
Delay of latency path: 0.25 ms
Training History
Downstream Upstream
Time Line Rate Max1 Max2 Max3 Mgn1 Mgn2 Attn Pwr CRCs FECs INP DLY Rate Max Mgn Attn Pwr CRCs FECs Mode Vendor State Exit Code Echo VCXO Rx Gain INC Tones
2010/01/18 21:05:51 GMT 1 1472 1476 664 664 12.0 3.0 67.7 16.8 64202 0 0.00 0.25 448 676 13.0 31.5 11.9 1878 402 G.DMT Annex A Alcatel 230/105 ERR_LOS_LIMIT -16.4 21.4 34.5 0
2010/01/19 06:41:41 GMT 1 512 540 1216 1216 12.7 19.0 68.2 15.1 189 0 0.00 0.25 448 648 12.0 31.5 11.9 19 1 G.DMT Annex A Alcatel 230/105 RETRAIN_HIGHER -20.7 24.4 34.5 0
2010/01/19 19:25:49 GMT 1 1280 1308 1236 1236 12.3 12.0 68.0 16.5 592 0 0.00 0.25 448 672 13.0 31.5 11.9 284 6 G.DMT Annex A Alcatel 229/103 N/A -14.1 24.2 34.5 0
Notes:
Time Time of last update
Max1 Max. rate at start of connection
Max2 Current or final estimated max. rate
Max3 Current or final estimated max. rate without INC
Mgn1 Noise margin at start of connection
Mgn2 Current or final noise margin
State Internal training state
Exit Code Cause of retrain
INP Impulse noise protection
DLY Delay of latency path
Bitloading
0000000445566677778877766555440000000057763454055626662332003422567776754888787776766554564555555544454544444444322002200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
0 16 32 48 64 80 96 112 128 144 160 176 192 208 224 240 256
19-01-2010 7:34 PM
20-01-2010 8:13 AM
20-01-2010 11:02 AM
20-01-2010 1:54 PM
20-01-2010 2:01 PM
20-01-2010 2:10 PM
20-01-2010 2:43 PM
Quote Basically Screengrab! let’s you take what you want from a web-page: the entire scrollable document, just the visible bit, or a draggable selection. Screengrab will even save just the contents of an individual frame.
20-01-2010 3:07 PM
20-01-2010 3:53 PM
From the speedtest on your first post, and the most recent it appears that your speed has pretty much recovered to it's previous levels.
20-01-2010 5:39 PM
Quote I have a new Thomson Tg 585 v7. Do you think it would be any better than the 2 Wire ??
Usually the 2 wire routers are the best on long lines. Good job with the Bit loading graph! but as pierre says, its pretty 'orrible, but then again its a VERY long line. Another Bit loading graph in the late evening would be useful, when the SNR is lower as it may give a clue as to what may be causing the SNR to fluctuate so badly.
20-01-2010 9:23 PM
