Cant use plusnet unless i use a vpn
Mustrum
Fixes: 81
Re: Cant use plusnet unless i use a vpn
Why would you not do as asked and reboot the router?
amxen
I did this new video was after a reboot
Fixes: 125
Hi @amxen the help desk readout you posted looks fine to me.
When testing are you using a wired connection plugged directly into the Hub One?
How many devices are there on you LAN, could one of them be downloading or streaming a large about of data all the time? Try disconnecting all the devices and just test on one wired device connected to the Hub One..
Are you using Homeplugs as these can give odd results.
Are there any other Plus Net users
@bobpullen it is a bit blurred but looking at the first speedtest I see IP Address, nslookup reports
Address: 91.125.86.183
The strange thing is the second test reports, viewed in the middle of the video
Address: 80.229.222.95
A fixed IP which is not this user ID
Bit odd!?
bobpullen
Fixes: 327
@Dan_the_Van - I applied a fixed IP to force the connection through our L2TP network. As mentioned, shot in the dark, and I wasn't hopeful it would help, but wanted to rule it out none-the-less.
Fixes: 125
@bobpullen
does seem odd it's not the users broadband username though?
https://community.plus.net/t5/Broadband/Cant-use-plusnet-unless-i-use-a-vpn/m-p/1886109#M350407
bobpullen
Fixes: 327
Might be waiting a script run to refresh the rDNS given I only applied it yesterday.
Will likely remove it later anyway given that it doesn't seem to have helped.
amxen
. I have tried it with a wired and a wireless connection it's all the same. Nothing is downloading or streaming. Even if it was how come it works fine with the VPN connected. My wife couldn't even get webpages to load on her laptop last night, So I told her she needed to download and install NordVPN but she couldn't even download NordVPN . I had to down load it on my laptop connected with the VPN then load it on her laptop. Once this was done hers was fine. Simple fact is nothing works unless we run a VPN
amxen
So I guess I'm stuck using a VPN till I can switch to a new provider . As I'm out of contract I'll start looking now I guess. Been with Plusnet for years as well with out a problem. They have certainly gone down hill
Fixes: 125
The problem with moving providers is the fault can stay with you.
If you are wanting to stay with plusnet then I would raise a fault with them at https://faults.plus.net.
Regardless of how many visits you've had there is an issue that needs resolving, it could be a network related rather than to do with the connection.
bobpullen
Fixes: 327
@amxen - how exactly is your network configured? i.e. what devices are connected to the router, how are they connected and what, if any, other devices are on the network? Things like powerline plugs, additional access points etc. in particular?
Something just doesn't add up. If the VPN throughout is unaffected, then I agree that it is difficult to accept that there's a physical fault with the line Huh
Champnet
Fixes: 18
@amxen
@amxen  How did you come up with idea that using a VPN would increase your speed ? Normally the opposite is true.
Also, have you changed any of the default DNS settings on either the devices or the router ? A VPN may have done this without your knowledge and not released it's own settings.
amxen
i was doing google searchs on what the problem could be and i came across a page that said some providers throtal your connection and a VPN would provent this. So i down loaded a free VPN this improved things a little so i thought i would try a paid one for a month and the deferance was instant.  We have some earthnet extenders the kind plug into the wall, that take the earth net upstarts with out having to run a cable for my wifes laptop when working from home. and one in the living room for the PS4 again so i dont have to run a cable . we have wifi laptops 2 , 2 phones that will connect when they are in the house a kindle fire for our son. and my wifes latop that conects to the ethernet when she working from home. amd a nintendo switch. and the TV . but even with all these things turned off with just one leptop connected with a ethernet cable next to where the cable comes into the house its the same.
amxen
I havent changed anything on the router i wouldnt know what i was doing if i did so wouldnt try
bobpullen
Fixes: 327
I've requested that somebody take a detailed look at your subscriber profile to see if anything is wrong with it behind the scenes but again, it's a shot in the dark. What I do have visibility of looks perfectly fine.
Rest assured, we're not intentionally throttling anything.
