Cannot access www.delicious.com / rapidshare.com
- Cannot access www.delicious.com / rapidshare.com
- « Previous
- Next »
Re: Cannot access www.delicious.com / rapidshare.com
12-03-2008 3:51 PM
So let me get this right.. This issue is happening because some scum are uploading/downloading innapropriate images of children, and your solution to plus.net customers is to buy membership to the site"? Great solution guys.
This shows how inaffective this IWF list is. Also how do you know that the IWF list is not incorrect or being "influenced" by corporations to protect their copyrighted products, as we all know that sites like rapidshare host all kinds of material wether legal or illegal depending on what country your accessing it from.
This just smacks of lazyness on Plus Net's side.. its easy just to blame the problem on some other company etc.. just like it was easy to try and blame the issue on malware. There must be something this ISP can do to stop/reduce this issue.
Also are all ISP's in UK using this IWF list? If so we as users could try and see if we are being fobbed off by asking a a friend/family member/collegue to try downloading the same links using their ISP and see if they get the same issue!
Message 61 of 66
(534 Views)
12-03-2008 3:57 PM
@Matt
I believe it was Bob, that said that authorised senor personnel could review the lists, but only under very strict controls with a full spin-off and audit trail. So in effect you are correct, it just PlusNet / IWF policies not the law that stops you access the list.
Chilly
Chilly
Message 62 of 66
(534 Views)
12-03-2008 4:23 PM
Quote from: RolandBlaze This shows how inaffective this IWF list is. Also how do you know that the IWF list is not incorrect or being "influenced" by corporations to protect their copyrighted products, as we all know that sites like rapidshare host all kinds of material wether legal or illegal depending on what country your accessing it from.
This on has been done to death on the forum before, and resolved to most peoples satisfaction.
And as for other ISP then most are already blocking or will be implementing the IWF block.
Message 63 of 66
(534 Views)
12-03-2008 4:32 PM
This really doesn't smell right to me, so I've re-raised the issue internally and we are looking at it. Updates as they come.
Kelly Dorset
Ex-Broadband Service Manager
Message 64 of 66
(534 Views)
12-03-2008 4:52 PM
@ Kelly and chillypenguin,
Thanks both.
Thanks both.
Message 65 of 66
(534 Views)
16-04-2008 9:38 AM
Hi all,
Just a quick heads up that we reckon we've got a fix for these issues. We're hoping to implement it throughout the duration of today. I'll keep you posted as to its success/failure.
Message 66 of 66
(534 Views)
- « Previous
- Next »
