turn on suggestions
Profile stuck at 7000
- Profile stuck at 7000
15-04-2008 5:10 PM
I had interleaving tuned off a while ago, and got a rock steady 8128Kbs connection. After the usual wait my profile went up to 7150.
Then I played around with my modem a week ago. It had to reboot several times and my profile went down to 7000.
I still get the full 8128 every time I reboot it (I've done that about once a day since last week) but my profile hasn's gone back up yet.
Like I said, it's been a week, now. Should I just wait longer for it to go back up?
Rick Fox.
Rick Fox.
Re: Profile stuck at 7000
15-04-2008 5:15 PM
Rick,
Are you referring to the PlusNet or BT profiling?
If you're referring to BT, you're already on 7150Kbps. If you're referring to PlusNet, it's now showing as 8000Kbps.
15-04-2008 6:45 PM
Hmm...
I checked it shortly before I posted - I've been checking every day when I get home. I could have sworn it still said 7000
Thanks very much for the response - panic over.
Cheers,
Rick.
Cheers,
Rick.
15-04-2008 7:24 PM
I'm guessing if you asked James a particular question he'd respond "Moi?"
(He did that to me after by stable rate dropped from 8000)
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
15-04-2008 7:58 PM
As I understand it, if you reboot more than a few times in quick succession the BT exchange may adjust your profile downwards in a ttempt to stabilise the connection (it assumes that there is a fault on the line). It'll take at least three days of continuous uninterrupted connection before your IP Profile is restored to its original value.
15-04-2008 8:16 PM
He's not talking about his IP Profile which was already back up to the maximum 7150 value. He's talking about the speed shown on https://portal.plus.net/my.html?action=stable_rate which sometimes needs a manual poke by someone at Plusnet.
LordFox checked - it was 7000
LordFox posted on here.
James said it is showing 8000.
No prizes for guessing what I think goes in the gap!
15-04-2008 8:22 PM
Jelv - yep, you hit it on the head!
I gave up trying to get bt speedtest to let me use it. I didn't realise that there could be some 'lag' on the stable rate page.
Rick.
Rick.
16-04-2008 10:30 AM
Ho hum.
*swiftly exits thread door right*
